v10 help
v10 help
i have recently aquired a 95 v10 complete computer and everything cheap was wondering A) how much is required to swap it into a 318 ram (95 model) B) has anyone ever carbed this engine instead of the computer F I . C) does anyone truely make aftermarket intakes for this? C) has anyone supercharged this motor and what were the results?I want to see just what this engine is truely capable of... thks matthew
I have yet to see someone carb one of these motors. I don't see why you would want to though.
I have heard of a local guy installing larger injecter and adding a programer to his V10 but that was some time ago. I'm sure that you could piece together a turbo kit for this motor as long as it was built to handle the pressure. There are cams, rockers and pistons for these motors out there, you just need to do some digging.
It would be a project............
Tranny is diff, mounts are diff, front springs are diff, fuel pump is diff, I built a whipple charger V10 2x dually single cab.....
hehehehehe
Stroke a 360, easier to do.
Oh, the carb, be kinda hard with no distributer.
hehehehehe
they share rods amd bolt up to the same transmission. the number 2 or 7 cylinder heads had eye brows in some of them would cause a cylinder to be lean and burn the piston some were replaced with new eng from mound road engine plant untill the internal specs changed with a new model year i dont remenber where we placed the new serial numbers but they were hand set on the block under the front deck surface or on the tabs aty the back of thew block it had to be where it could be read when installed these remans had to go out within factorysp[ec and had to runfor 2 hours at rated or remaned exceeded all factory values do turn your back on the feul injection the ge t more hp out of a 3 liter 6 than my 1969 4bbl 318
