1990 dakota 4 banger to v6 or v8 ?? help
Old Dec 8, 2009 | 03:08 PM
mopar nate's Avatar
i have a 1990 dodge dakota it has a 4 banger on a five speed i want to get v8 or aleast a v6 in it how hard and what will i need. will the trans be able to handle a v6 i know a new trans will be needed for a v8..... same question for the rearend.....will 6v drop into the 4banger k-frame ??? tight budget btw thanks nate
Old Dec 8, 2009 | 03:17 PM
johnthegoalie's Avatar
thinkin with me dipstick
mopar action has been doing something similar over the past few months- fast v-8 dakota on a budget
Old Dec 8, 2009 | 03:27 PM
mopar nate's Avatar
do you know where the article is i couldnt find it if you could that would be great
Old Dec 9, 2009 | 04:29 AM
Is this 2wd or 4wd?
I think that they used the same 4 cyl that came in the Jeeps and if you have a manual then it would be an AX5 tranny (can't handle anything more than a 4cyl motor). A lot of what way you go and what I would suggest to you depends on my first question though along with; What is the purpose of this truck going to be?
Old Dec 9, 2009 | 10:33 AM
mopar nate's Avatar
it gana be my everday just for ***** and giggles and its a 2wd ...i just want some power in it..
Old Dec 10, 2009 | 03:50 AM
You can get a magnum V6 and tranny and swap that in there with the wiring and computer, of course you could do the same with a V8 as well. Whichever way you go, you will have to splice the harness into the one that you have now somewhat. What splices and where I'm not sure if.
Since you have a clutch pedal setup, you can go with an AX15 of NV3500 (stronger of the two). You will want to upgrade your rear axle at the same time. You will also need to change out the torsion bars. I know that those generation Dakotas came with V6s (4x4 models) so if you want something easy to swap in, maybe look into getting a whole vehicle that was in an accident and swap everything in.
better_sideways
Sep 26, 2021 11:58 AM
gilligan
Apr 8, 2011 08:09 AM
DonaldTheGiver
Oct 20, 2010 05:05 PM
dustedmopar
Apr 27, 2010 08:21 PM
cide
May 17, 2008 02:10 AM
