88 dakota 2wd transplant v6 to v8
Old Jul 21, 2009 | 01:58 AM
For the fuel pressure, install an inline manual regulator w/gauge.
For the fan, there are some 16" fans out there that don't cost a whole lot and the thermal switches for them are pretty cheap.
I'd look into a finding a 2wd 727 for the 318 or 360 as the one behind the 3.9 probably won't last too long.
You will need a rear sump oil pan for the swap (i believe).
I'm not sure about the motor mounts or the flywheel though. I think that the mount should work though, you may need to just fab some up.
Old Nov 10, 2010 | 07:14 AM
mopar 69's Avatar
interested in selln the 3.9 and tranny? what the condition and mileage but id need the complete setup mine is 2.2 5spd carbd
Old Dec 28, 2010 | 11:26 PM
LOVEmyMOPARS's Avatar
I swapped from a manual trans to a 904 behind my v-6 in my 90 4X2 and added 2inches to make the bracket far enough forward to make it work with the manual crossmember. I have been doing research and have been thinking about a 318 to put in mine and found that if I were to take the 2 inches back out of the bracket a small block v-8 could fit with a 904 moving the engine back 2 inches and no fan it would clear the radiator. I have the same issue as you. The cost, I have seen engine swap kits upwards of $600 that doesn't include exhaust headers, oil pan, shortening the driveline. Good luck If you can find an inexpensive route.
SeanG 273
Sep 11, 2012 01:32 AM
highwood
Jun 15, 2011 10:00 AM
panda!
Jul 11, 2009 06:30 PM
68 Sat
Jul 6, 2009 07:45 PM
rr69half6bbl
May 9, 2009 05:13 AM
