Is a 85 Dodge 318 short block w/heads compatible with a 94 Jeep 318 motor?
Old 01-14-2009 | 03:05 AM
No it will not unless you feel like doing a lot of work. The 5.2 in the jeep is a magnum motor. THe 5.2 out of the 85 dodge is a LA motor, pre-magnum. The heads are designed differently, the intakes are completely different, the oil gallies from the block to the heads are different (so you can not just swap out the blocks or the whole top end), The exhaust ports are different, etc. You need to find a magnum motor (92 and newer). The small block motors that are 91 and earlier are all LA motors. You should be able to find a magnum 5.2 used and complete for a few hundred bucks. Any out of a 94-01 ram truck, 93-98 jeep grand cherokee, 97-01 dakota, 97(?)-01 durango will work.
Old 01-14-2009 | 03:06 AM
oh yeah, welcome to the forum!
Old 01-14-2009 | 11:38 AM
Actually the years on the dakota that I gave you are wrong. They started putting the Magnum 5.2 V8 in the dakotas back in 93 so any dakota from 93-01 with a 5.2 will be a magnum.
Old 01-14-2009 | 01:27 PM
Welcome to the forum
Old 01-15-2009 | 03:52 AM
any pics?
Old 01-15-2009 | 01:22 PM
2x on the pics
Old 01-15-2009 | 09:06 PM
challenger's Avatar
Welcome LittleSpark and 3x on some pic's
dpmalibu
08-03-2013 06:05 PM
Shannon
03-02-2013 01:27 PM
PatsPolara
01-29-2011 02:50 PM
WailingWallabee
07-14-2009 03:18 AM
ProEmaster
03-01-2007 12:19 PM
Quick Reply: Is a 85 Dodge 318 short block w/heads compatible with a 94 Jeep 318 motor?
