Jeep Liberty crd limp mode
2005 crd, will idle for hours running great.
when driving it, as it changes to 3rd gear, it goes into limp mode. Cranks right back up.
EGR has been deleted and fuel filter changed. Also changed the fuel pressure sensor on the rail.
Codes are the same; EGR, left bank, injector 1.
Does anyone have any suggestions?
When it shifts into 3rd gear, Dose the car die?
If so i would say its a transmission problem, and not relate to the other codes.... Use a DBR III or Equivalent scanner and check for trans codes in the TCM (Transmission Control Module) My first guess would be a solenoid pack has gone bad.
94redram
Nov 9, 2016 06:34 PM
