1971 Dodge D100
Guest
Posts: n/a
1971 Dodge D100
Just installed a edelbrock intake w/ a holley 600 - headers - and HEI dist and coil on a 318. I am getting some backfiring when ideling and on the road - hesitation when taking off. Timing in right on - and carburetor is new, so thinking it should be fine, any suggestions?
timing chain may have jumped a tooth. does it get any better the more the motor revs up? is the carb adjusted properly? Holleys take some time to get just right. if its backfiring then it sounds like a timing issue.
im having a simular problem im slowly narrowing it down though my vac adv needs adjusted ive backed it out some and solved the backfire still need to turn it out more its hesitating part throttle anywho theres alittle allen head screw inside of the vac adv where the hose hooks onto try adjusting it some ,....... it helped mine after i added new intake , carb ,redid the heads , and everything else was new
72D100dodge
Oct 23, 2011 02:58 PM
KustomsandChoppers
Aug 3, 2011 12:02 PM
