1971 Dodge D100
Old Oct 2, 2008 | 02:49 PM
chlngr1970's Avatar
Burnt valves? Stuck valves? Is it consistant, like a timing issue, or inconsistant? Does it do it all the time, or when the motor is warm/cold...
j
Old Oct 2, 2008 | 04:04 PM
timing chain may have jumped a tooth. does it get any better the more the motor revs up? is the carb adjusted properly? Holleys take some time to get just right. if its backfiring then it sounds like a timing issue.
Old Oct 2, 2008 | 04:05 PM
and welcome to the forum!
Old Oct 2, 2008 | 04:43 PM
ef8340's Avatar
Senior Member
im having a simular problem im slowly narrowing it down though my vac adv needs adjusted ive backed it out some and solved the backfire still need to turn it out more its hesitating part throttle anywho theres alittle allen head screw inside of the vac adv where the hose hooks onto try adjusting it some ,....... it helped mine after i added new intake , carb ,redid the heads , and everything else was new
Old Oct 6, 2008 | 02:38 PM
challenger's Avatar
if its a 71 then chances are your chain has stretched a bit so i would try and advance the timing about 2 deg, and also check the chain and see how much its stretched
72D100dodge
Oct 23, 2011 02:58 PM
redneck9507
Aug 30, 2011 05:48 PM
KustomsandChoppers
Aug 3, 2011 12:02 PM
trever.turner27
Mar 7, 2010 04:39 AM
33harner
Jun 7, 2009 11:18 AM
