383 or 440?
Old Mar 1, 2015 | 09:40 PM
Jgriggs29's Avatar
383 or 440?
Just getting into my first Mopar build👍 unfortunately I cannot pour all the money I want into my car, but I have a few things to start with. I have a 1977 440 and a 1970 383. Both the bottom ends in the motors are great so I can stick with stock Pistons and whatnot.
My question is what's going to be the better build for a consistent strip car? I'm putting my setup in a 1973 Plymouth scamp with 4:30 gears
Parts I have:
509 lift 289 duration cam w/lifters and matching springs
Factory 906 heads w/ 1.5 ratio roller rockers
Edelbrock street master intake w/ Holley 750 double pumper
And an msd digital 6 ignition... The rest of the Money I have will be spent on a starter battery...etc so what motor should I put together with that setup? I know the 440 had horrible compression but will it still perform better than the 383?
Old Mar 2, 2015 | 01:36 PM
Mr.4spd's Avatar
440, though headers will fit better with the low deck 383. The compression will be helped some by the earlier heads (906)
Old Mar 2, 2015 | 01:53 PM
oldguy's Avatar
oldguy
The more cubes the better
Old Mar 22, 2015 | 05:01 PM
camaro440's Avatar
I defiantly would got for the 440. Already have the biggest cubes Dodge came out with and you could eventky go with better heads and have a solid beast of a motor with a can and intake that matches up. Also with a great carb slapped on it could make some great power on a budget
labradorian70
Sep 24, 2014 09:44 AM
4004speedrunner
Dec 9, 2012 11:43 AM
Database13
Jul 2, 2009 02:28 PM
Jim Mac
Feb 23, 2009 01:00 PM
Pito's 74
Oct 5, 2008 11:29 PM
