Low 9 sec Cuda .. 28x10x15 or 29.5x10x15 ?
Old Mar 22, 2015 | 01:30 PM
raffaplymouth's Avatar
In my Cuda ..would jump from 28 to 29,5 for improve 60 ft and top end speed ... Now with 28 tires with 4.10 ratio my best ET is 9.79 at 142 mph ..1.48 60 ft .. 7200 rpm at finish line .. Look like too rpm ?? Because my power peak is at around 7000 rpm ... My goal is low 9s !!
Old Mar 22, 2015 | 01:32 PM
Sorry .. Would jump to 29,5x9x15 Not 10
Old Mar 22, 2015 | 03:59 PM
moe7404's Avatar
my pappy allways said. the faster you go the harder it is to go faster.
Old Mar 22, 2015 | 04:28 PM
motasupra's Avatar
That car sounds awesome. We run a 29.5x10.5W R15 its a total of 13" wide and goes like hell off the line. but the best pass in our car was 10.30'S
Old Mar 22, 2015 | 09:05 PM
The added weight May make it go slower ????
Old Mar 22, 2015 | 09:30 PM
Drag Pak's Avatar
Raffa
pm sent
Old Mar 23, 2015 | 03:36 AM
wow !! you have this 29.5x10.5 with 10" wheels ??? wich backspacing ??? i think not fitting in my cuda with factory leaf spring location and factory fender !! remember my car is streettable .. i drive everyday .. and in september my best ET was 9.78 and 1.48 60 ft
Old Mar 23, 2015 | 04:00 AM
hosting immagini
Old Mar 24, 2015 | 07:55 PM
motasupra's Avatar
Our back fenders are rolled. we may go back to stock fenders when we put it back on the street. 10" with 5.5 back space weld drag lite. calvert mono leaf rear and caltracs.
P.S. that car is bad. pump gas?
Old Jul 15, 2015 | 01:40 PM
.. Yes Pump gas .. In Italy Pump gas is available in 100 octane ... In The last race this car had Made 9.64@143 60 FT is very bad 1,51 ..this car have stock 45 years Old leaf Springs ... And Caltracs ..
28-10-15 tires ...im working for install mono leaf and 9 way shock and offset hangar for move The leaf inside !!
Old Aug 10, 2015 | 07:53 PM
Guys . Anyone know the difference in the springer hanger ?? Have two hole for the spring eye ... Wich is better ? ... Lower or upper ?
Old Sep 10, 2015 | 08:50 AM
caricare immagini
Old Sep 10, 2015 | 08:59 AM
Drag Pak's Avatar
Bent housing? Got hook? Typical 8 3/4! Dana 60 time?
Old Sep 10, 2015 | 09:10 AM
Magoo's Avatar
Thumbs up Your Cuda
Originally Posted by raffaplymouth
--- Neat - Old Mopar.
Old Sep 10, 2015 | 09:23 AM
YES !!! DESTROYED AFTER 5 PASS WITH NEW MONOLEAF !!!!! IM UNDECIDED IF PUT NEW CASE WITH BILLET CAPS .. BUT I DONT SUCCESS TO FIND 4.10 RING AND PINION PRO GEAR !! YOU THINK IS TIME OF DANA 60??
Old Sep 10, 2015 | 09:25 AM
image share
Old Sep 10, 2015 | 09:28 AM
THIS IS THE LAST PASS 9.7@146 KMH
free image hosting
Old Sep 10, 2015 | 10:05 AM
Drag Pak's Avatar
Time for Dana S60 (Strange) with chromoly tubes, spool and gundrilled axles.
I was waiting for these pictures to show up!
Old Sep 11, 2015 | 05:32 AM
If you stick with the 8 3/4, you need a spool and you should be changing the ring a pinon every 100 pass's or so (before it breaks).
I'd say it's time for the Dana, and you probably broke your trans also.
Old Sep 11, 2015 | 01:58 PM
i have found in italy a Dana 60 OEM 1967 at good price , i can convert in 35 spline ... have power lock carrier
Old Nov 27, 2015 | 06:54 AM
New Rear End !
invia immagini
Old Nov 27, 2015 | 07:06 AM
host image
Old Nov 27, 2015 | 08:18 AM
Hope it Works as Good as it Looks Raffa.....
Did you stay with the 4.10's or go with a 4.30 gear?
Hoping for the new best of a 9.50 for you....
Old Nov 27, 2015 | 10:18 AM
  #24
Drag Pak's Avatar
You might want to try that Caltrac bar in the lower hole/closer to parallel to the ground.
Old Jan 5, 2016 | 02:25 PM
  #25
Hi... thanks for this info ....!! you think is better on lower hole ??? i can also move the spring eye location from lower to upper hanger hole ... let me know ...
Old Jan 5, 2016 | 04:08 PM
  #26
Drag Pak's Avatar
I think you have to test to find out what gives the best 60 ft. I believe there will be a difference from top to bottom, depending on how much axle - body separation you get/need and still dead hook.
raffaplymouth
Sep 20, 2016 03:06 AM
AARinOntario
Aug 9, 2012 08:45 AM
70newport
Mar 26, 2010 02:34 PM
summerj
Feb 6, 2008 08:34 PM
BRAKE
Oct 24, 2006 09:18 PM
