Need help with 318 poly combination!!!
Old Dec 31, 2009 | 12:08 AM
theomahamoparguy's Avatar
how did he fit the "poly" in the 64 dart. any way, yes that is too much carb and intake for a poly. Wait a minute, are you sure this is a poly. I've never heard of a tunnel ram for a poly motor. Dual carbs yes, dual carbs on a tunnel ram, no. If you did have a poly with a tunnel ram and two 600 cfm carbs, it would be too much. Poly heads dont flow all that well, particularly on the exhaust side.
Old Jan 23, 2012 | 06:30 PM
Unless it is older, maybe 60-62 Dart IT would not have a poly from the factory. 63 started the A body Dart. Factory V8 for a 64 Dart would have been the first of the 273 LA motors..
Even the early 60's would be a cool car, make sure what you have before deciding what to do with it..
Post a picture..
Old Jan 24, 2012 | 09:30 AM
I have "heard" of Poly engines installed by people in Darts, so it's not impossible, just not original
We need to see some photos of it!!!!
So far as the problem, probably either ignition or fuel
Go over the ignition from stem to stern. REPLACE the plugs with new.
TEST the wires AND coil wire. Use an ohmeter, clip it to each end, and shake the wires to show up intermittent connections. The resistance will depend on what sort of wires you have, the big thing is that they all show about the same.
Examine the cap and rotor for damage, if any question, replace both.
If it has points/ condenser, replace them. If possible, round up someone with an igntition scope and see what the spark looks like
For fuel, there are specs in the shop manuals for checking pump pressure and volume. If you have an electric pump, l figure out what the model is and Google up the manufacturer's website for the volume specs on it.
Inspect or change any rubber jumper hose in the fuel system. There's one back at the tank, and one up at the mechanical pump if used. These get old and can collapse under pump suction
Also suspect the strainer in the tank. You can remove the fuel cap and blow air back through the supply line and get a feel for "if it is clear."
If none of this brings results, "rig" a safe but temporary fuel pressure gauge on the pump output. Go for a test drive(s) and watch for fuel pressure drop under hard acceleration.
Has the car been in long term storage? What shape do you think the carbs are in? Could they be gummed up with old fuel and varnish? The internal metering ports, jets, etc, of the carb could be AFU
Old Jan 24, 2012 | 12:28 PM
moparted's Avatar
y revive a 2
+ yr old topic?
Old Jan 24, 2012 | 05:15 PM
Originally Posted by moparted
y revive a 2
+ yr old topic?
Oh hell. I forgot to look.
69 powerwagon
May 29, 2013 10:28 AM
ykf7b0
Sep 20, 2011 08:29 PM
TallChris
Dec 1, 2010 03:29 PM
66coronetgirlie
Aug 9, 2010 10:41 PM
ferrell450sel
May 6, 2009 10:41 AM
