small block roller cam question
Old Feb 14, 2011 | 05:57 PM
ellisfan's Avatar
I have a comp 308 solid roller I want to install in my 340.both comp and crane tech sites say I must modify my oiling system.what mods need to be done?Any help on this would be appriciated.
Old Feb 14, 2011 | 09:39 PM
condor74's Avatar
Generally that means bushing the lifter bores and restricting oil to the valve train. What happens with a Roller cam is the lifter sits up higher and when the lifter goes up on the lobe of the cam it uncovers the oiling hole momentarily causing a loss in oil pressure.
I would take it to a machine shop familiar with running a mopar with a roller cam. I have also read that this mod is typical in Chevrolets but not needed in Mopars. Alot of the cam manufacturers have all the instructions geared towards Chevys. I would call Mopar Performance or Muscle Motors or someone else you trust who Races Mopars. They would be able to tell you for sure. Good luck.
Old Feb 15, 2011 | 04:26 PM
ellisfan's Avatar
Thanks,I'll give that a shot.
pipdog69
Mar 13, 2012 11:01 PM
q8_barracuda
Dec 30, 2011 04:30 PM
moparjohnson123456
Jun 14, 2011 01:28 PM
bugy
Feb 1, 2011 08:51 AM
norcalmopar
Aug 6, 2010 03:51 PM
