Small block stroker?!
Old Feb 4, 2009 | 11:27 AM
Polaradude's Avatar
Check out 440 source on the net, they have rotating assemblies, you may get some insight there.
sorry about the 440 source info, the smallest they do is 383.
Old Feb 4, 2009 | 11:29 AM
see how much it will cost you altogether to do the stroker kit and upgrade your tranny (cuz your going to need to build it a little stronger) and compair that to a big block and tranny combo that you can do a mild build on and get the same results and still have plenty of room to build and go faster if you want. Take into consideration that you'll get some money back for the 340/727 combo.
Old Feb 4, 2009 | 12:22 PM
Polaradude's Avatar
hughesengines.com sorry again about the 440 source.
mancini also sells 318 stroker kits
Old Feb 4, 2009 | 05:59 PM
Polaradude's Avatar
Glad I could help.
Old Feb 5, 2009 | 03:33 AM
Didn't Mopar Magazine stroke a small block a few years back? I thought I remember reading an article in there.
Old Feb 22, 2009 | 03:03 AM
  #24
You can only flow in as much as you can flow out.
If your not flowing out what you flowed in, your not going to get that much more in there and your only going to be hurting yourself.
