Will they fit? (Slicks)
Old May 14, 2011 | 06:37 AM
Snoman's Avatar
Hi Guys, I was at a swap a couple weeks ago and picked up some m/t drag slicks cheap. But they are big will they fit under my 74 roadrunner. they are 29.5 x 10.5 and if they do what size rim should i use and what offset. Thanks
Old May 15, 2011 | 03:01 AM
That is big. You'll need to run an 8.5-9 inch wide rim and maybe lif tthe back end a little to get them to clear. As far as BS goes, I'm unsure.
Old May 15, 2011 | 03:48 AM
Tim is right on the wheel size.... On the BS there is a tool that you can install in place of a rear wheel and it will tell you how big and what BS you can put under your car... I have never used one but I have seen them in Jegs and Summitt..
Just remember that the more the BS the more you are moving your tire in....
Old May 15, 2011 | 05:35 AM
Snoman's Avatar
OK Thanks, If I have to buy some different slick what size do you guys recomend for size 28x9 OR 8? Thanks again
Old May 16, 2011 | 03:06 AM
What size tires are you running right now in the back? Do they have any issues with rubbing?
Old Jun 2, 2011 | 05:55 AM
Snoman's Avatar
This is my first set of slicks for the car, I am running 14in. x 10 wide cragers with 24 in tires. Thanks
Old Oct 5, 2011 | 09:56 AM
burnoutking-1's Avatar
I don't think they would fit, unless the roadrunner has more wheel space than a challenger. A 10.5" M/T slick is actually around 13" wide.
I have some 60's on the back of my challenger that measure 10.4 with sidewall, and I have less than a quarter inch between the tire and spring, and a finger between the fender and tire.
I guess a lot less backspace and/or a thick spacer and the backend a few inches higher would do it.
Leaf spring relocation kits aren't very expensive, and would be the way to go.
Old Oct 5, 2011 | 10:10 AM
JS23's Avatar
Look for a 9' wheel with a +10mm offset.
Make two measurements drum surface to fender lip and then drum surface to leaf.
Old Oct 5, 2011 | 03:11 PM
Try this : http://www.rimsntires.com/specs.jsp
h340
24
Dec 18, 2014 09:19 AM
rcknrolfender79
Apr 12, 2010 05:30 AM
Moparknighthawk
Apr 2, 2010 07:42 AM
Big D
Mar 5, 2008 01:23 PM
