400 BB Vacum advance
Old Dec 29, 2011 | 04:46 PM
Razorblade72's Avatar
Talking 400 BB Vacum advance
Hello everyone. I have a 78 D200 pick-up. It was stock and I put headers, an aluminum intake, and a holley 4-barrel on it. Now the vacum Advance is advancing the time timing way out of sight. Like 40 degrees plus. It gets to poping and pinging. I am wondering if anyone knows the remedy to this problem. Is there an adjustable vacum advance that can be purchased seperate for a stock distributer. Is that the solution? What is the solution to this problem? Thanks for any advice you can give.
Old Dec 29, 2011 | 04:54 PM
I would check your vacuum advance connections.. I suspect you have it hooked to full time vacuum source. Check your initial timing with the advance disconnected
Old Dec 29, 2011 | 05:07 PM
mr340's Avatar
I agree, sounds like you missed the distributor port and hooked to a direct manifold vacuum.
Old Dec 29, 2011 | 05:30 PM
On a Holley 4 barrel there is a timed vacuum source on the passenger side near the top of the carb. If you have it plugged to the bottom of the carb..ie the base plate that's your problem. There should be a picture of the carb and the vacuum connections in you Holley installation manual that came with the carb.
Old Dec 30, 2011 | 06:00 AM
rickyr's Avatar
bremereric is correct, the ported vacuum is on the pass. side up high on the metering block. this is where the dist. should be hooked up
Old Jan 1, 2012 | 12:04 PM
challenger's Avatar
welcome
Old Jan 1, 2012 | 05:28 PM
Old Jan 2, 2012 | 02:22 AM
Welcome to the forum. While on here be sure to check out the Mopar of the Month contest..
66FuryBoy
Mar 16, 2011 02:30 PM
68camperspecial
Apr 2, 2009 01:46 PM
Kevin71
Feb 11, 2009 07:51 AM
gotdust
Aug 10, 2008 12:14 PM
General pavelka
Sep 23, 2007 04:31 PM
