67 Coronet 440
Old Aug 23, 2011 | 11:44 AM
Covalent23's Avatar
67 Coronet 440
Hi, I'm new here and I got a couple questions. So I'm looking at a 67 coronet 440. It has a 383 high performance engine with two four barrel carbs. I'm thinking about buying it, but the only problem is that its missing both carburetors. How much would it cost to replace them? What kind should I get? And how would I put them in?
Old Aug 23, 2011 | 12:14 PM
rickyr's Avatar
Hi,
Welcome to the forum
I would put 2 390 cfm Holley's
part # 0-8007
that is as long as the bolt pattern on the intake is 5 3/16" by 5 5/8"
center to center where the carbs bolt on.
direct from Holley they would be $381.39 each
maybe cheaper from Summit racing.
Old Aug 24, 2011 | 12:37 PM
do you know what kind of cam is in the car, and any other work done to the motor?
Old Aug 24, 2011 | 01:45 PM
Covalent23's Avatar
I don't know the cam, but its all original as far as I know.
Old Aug 24, 2011 | 01:55 PM
rickyr's Avatar
You can check the engine vacuum @ idle (in gear if it is an auto trans)
and if it is 13" or more the stock power valves in these carbs will be good
if it is lower than 13" cut your # in 1/2 and that will = the size power valves you will need to run
example 9" of vacuum will need a 4.5 power valve
and so on
that is for power valve size
as far as carb size I wound not go any bigger than 390's
unless it is built to rev very high
A 383 @ 5500 PRM calls for a 600 with a single carb
Thanks
Old Aug 24, 2011 | 02:15 PM
Covalent23's Avatar
I cant start the car, because someone stole the carbs off the engine. Thats the only thing thats keeping me away from buying the car.
Old Aug 24, 2011 | 03:48 PM
rickyr's Avatar
Starting it would only be to size the power valves
If you chose to buy it
You can go on and get it and get these carbs and after you install them
then you can fire it up and check the vacuum
Old Aug 24, 2011 | 04:46 PM
Welcome to the forum.. Be sure to check out the Mopar of the Month contest... See the sticky for the simple rules and then you can help choose the winner each month...
Old Aug 25, 2011 | 04:35 AM
A dual carb setup is not really that much. As long as all they stole was the carbs and left the linkage and everything else that is. What did it have on there for carbs before?
SteveRT
Oct 15, 2014 04:24 PM
Captainkirk2931
Jan 6, 2009 11:37 PM
hemibou
Apr 18, 2008 05:01 PM
66utiline
Jan 29, 2008 03:08 PM
499coronet
Feb 18, 2007 12:48 PM
