'68 318 radiators
Old Dec 1, 2016 | 02:40 PM
RiffRaff's Avatar
'68 318 radiators
hello everyone,need info on replacement radiators,i have 2 1968 fury III's,,(also a 67 383 VIP)both are 318/auto and a/c,both need rad's.i have tried 2 aluminum ones,a kks and an engineered cooling products from ebay,they're both close but not quite,upper/lower hose connections are not correct,should be 1 1/2'',kks 1 3/8,ECP 1 7/16,as well as the physical build of the aluminum's make them incompatible with the shroud,they're just smaller,both are an inch narrower.if my photos go through with this post,you can see the problem is also with the top tank.the new aluminum's dont take into consideration the two piece upper tank of the original,im wondering if anyone has had this problem before and knows where to get oem brass and copper replacement's,,,thank you
Attached Thumbnails '68 318 radiators-dscn0287.jpg   '68 318 radiators-dscn0286.jpg   '68 318 radiators-dscn0283.jpg   '68 318 radiators-dscn0282.jpg
Old Dec 1, 2016 | 03:03 PM
Does this look correct?
https://www.summitracing.com/parts/s...model/fury-iii
Old Dec 1, 2016 | 03:23 PM
RiffRaff's Avatar
thanks Iowan for reply,sadly no,thats not the right one,we're "neighbors" by the way,if i assume correctly that your user name indicates you live in Iowa,im not far to the north, up in southern mn
Old Dec 1, 2016 | 03:44 PM
Just east of Mason City here, isn't there a place in Rochester that repairs re cores rads?
68hemidart
Nov 4, 2014 08:18 AM
68hemidart
Feb 25, 2013 05:24 PM
fivepoint
Jul 23, 2011 07:02 PM
LittleSpark
Jan 15, 2009 09:06 PM
ProEmaster
Jun 6, 2007 11:31 AM
