68 Coronet
Old Oct 7, 2012 | 04:13 AM
MEC7's Avatar
68 Coronet
Recently acquired a 68 Coronet with the stock 273 / auto trans setup. Also got a 64 383 separately and I am working on it to bring it up to about 400 hp. First time digging this deep into an engine (never did a lower end before). Anyway, it is apart and all looks good. I want the car to be a daily driver, so no heavy changes will be made to the pistons, cam or heads. But I would like some advice on new pistons (slight overbore is ok), maybe a 3/4 cam, headers, new intake manifold and carb as well as headers, roller rockers, roller timing chain, hot coil and a nice open exhaust system. Any recommendations for those parts or others would be great.
Old Oct 7, 2012 | 08:19 AM
400HP at the crank or rear wheel? If at the rear wheel, you might want to shoot for ~450HP at the crank. Either way, it is very doable. Here is what I would do.
Mopar Performance Cam
Mopar Performance Dual Plane Intake Manifold
Edlebrock 650 carb
Pair of 915 heads
Pair of shorty Hedman Street Hedders - #78076
Clevite 77 bearings
That setup is designed for a street vehicle/daily driver IMO. There are a ton of other options on everything though out there.
Old Oct 8, 2012 | 05:44 AM
rickyr's Avatar
[QUOTE=78D200;92399]Welcome!
Edlebrock 650 carb
Pair of 915 heads
Clevite 77 bearings
welcome to the forum, I would go with long tube headers, shorties do not do much for power,
Also a Holley is more for performance, Edelbrock is good for point A to point B
Every NASCAR ran a Holley carb intill this year when they went with Holley EFI
