72 cuda fuel gauge issue
Old Aug 28, 2013 | 09:19 AM
72cuda's Avatar
Exclamation 72 cuda fuel gauge issue
Any ideal why my fuel gauge isnt reading right? it has a new sending unit an tank but it only will read up to 1/8 a tank when full. i took sending unit out thinking float was cracked and it wasnt ,tested it with multi meter and all was fine. HELP
Old Aug 28, 2013 | 10:17 AM
If the sending unit checks ok ? I would make sure you have a good ground. You may need to check the dash gauge
Old Aug 29, 2013 | 04:55 AM
Welcome to the forum... Be sure to check out the Mopar of the Month contest... The ground suggestion sounds right to me......
Old Aug 30, 2013 | 08:21 AM
rickyr's Avatar
welcome
Old Aug 30, 2013 | 08:48 AM
It seems to be a well known internet "fact" that repop senders aren't quite right, but FIRST you need to see if the gauge is actually correct.
First, if you are still using an old original instrument voltage limiter, I'd just replace it "because." RTE sells replacement solid state ones, or if you Google around you can actually build them
Next get some resistors from Radio Shack and test the gauge for accuracy, OR diddle with fuel level to get a specific resistance.
You want about 10 - 15 ohms for full, 23 -- 25 ohms for 1/2, and 70 -- 75 ohms at empty
For example you can buy a pack of four 100 ohm, 1/2 watt resistors and wire all four in parallel. This makes a 25 ohm resistor that should give you 1/2 scale after about a minute with power on. Or, you can siphon/ add gas until you get to that point, and or the other values to check full or empty
You can also use your resistors to check the temp gauge, as well as oil if equipped. All the gauges use the same scale movement.
Once you know the gauge is correct, it's a matter of bending the arm some to get empty to read right. Some guys have added series resistance to get "full" to read right.
I've seen no good writeup that shows a sure fire cure for the problems with modern senders.
19newport72
Mar 27, 2024 06:44 PM
cletis
Cuda Specific Discussion
Jun 1, 2011 04:29 PM
sgp7679
Apr 21, 2009 06:27 PM
Evnas
Apr 12, 2009 06:13 PM
78trailduster
Apr 1, 2009 07:23 PM
