72 Duster
Old Mar 4, 2012 | 04:15 PM
Dawayne Levenberry's Avatar
72 Duster
I have a 72 plymouth Duster, when the time comes i want to race it at the local drag strip in Manassas, VA. It is a stock slant 6. I want to know what is the best engine to put in it. How big can I go. Money is not really a problem. what would I have to change in the car to support a V8.
Old Mar 4, 2012 | 04:51 PM
First of all welcome to the forum.....
If i had your situation as you explained it I would go all the way and put a BIG HONKING HEMI in that Duster... You will also want a Dana 60 rear and probably a 727 tranny.. New HD suspension with coil over shocks and a 4 link in the rear.... But that is a VERY large budget......
While on here be sure to check out the Mopar of the Month contest.. See the sticky for the simple rules and then you can help choose the monthly winners......
Old Mar 4, 2012 | 04:52 PM
PK1's Avatar
PK1
Blank check for a Duster... ? Hm....
Track only? Dual purpose? Cruiser primarily?
Do you have a ET goal or class you want to be in?
Old Mar 4, 2012 | 07:30 PM
mr340's Avatar
Drag strip in Manassas??? Never knew it was there. and all that time I spent fourwheelin' on the back trails at Quantico... Put a nice 360 in that A and go drive the wheels off it!
Old Mar 4, 2012 | 09:33 PM
Welcome aboard we like pics. Take a 400 and do an easy 451 stroker. Shumacher motor mounts and TTI headers with 2.5 X pipe duel exhaust all the way to the back.
Old Mar 5, 2012 | 02:48 AM
Track only? Dual purpose? Cruiser primarily? Do you have a ET goal or class you want to be in?
X2^
Is this going to be a full blown drag racer only that you will trailer or do you want to drive it on the street too?
If money is no object, then I would go with a stroked BB, fuel injected, and super charged. Try and build a tranny to handle that kind of power, a rear end with cryo treated gears and 300M shafts, 4-link rear, frame stiffners/re-enforcements and a roll cage.
If you want it streetable, then I would throw in a healthy 440, 727, D60 rear, 4-link rear suspension, upgrade the front suspension and install a cage.
Old Mar 5, 2012 | 04:23 AM
duster sweden's Avatar
sb 360 stroke 408 and you get no problem with space..
Old Mar 5, 2012 | 04:33 AM
I had one of those in full race mode... Mine started as a 340 and ended up a 396.. One bad a$$ small block!!!!!!
Attached Thumbnails 72 Duster-copy-motor-right-2.jpg   72 Duster-motor-left2.jpg
Old Mar 5, 2012 | 06:12 AM
rickyr's Avatar
Old Mar 9, 2012 | 08:24 PM
challenger's Avatar
Welcome
Carrico_IL
Jul 18, 2018 05:15 PM
