76 duster exhaust manifold
Old Sep 16, 2016 | 12:44 PM
dannybritt65@yahoo.com's Avatar
My 76 duster with 360, has two diff headers & I can't seem to get the drivers side to pull off far enough to get a gasket replaced so I want to swap out to a better set up, summit says to use 5 diff ones, 1st choice is hedman 78500, but it exists right where the steering box is & I can't tell if the box is going to be in the way, another choice exits in the rear but once again, can tell if starter is going to be an issue, anyone dealt with the a body issues like this, just want it done right, preferably the first time, thanks guys
Old Sep 16, 2016 | 01:42 PM
Dont know where that came from hahaha
Old Sep 16, 2016 | 02:14 PM
Wtf you talking about lowan
Old Sep 16, 2016 | 02:28 PM
Most have success with Doug's or TTI. If you troll around "For A Bodies Only" forum you might get some ideas. I've read where they should have fit with power steering but was tight then found out later it was an engine swap with not same year K member and engine mounts and grief like that.
I'd want to be sure if your car was truly original pieces before shelling out the dough, I personally don't like block huggers. I don't have experience for you as I usually make my own or modify store boughts.
Old Sep 16, 2016 | 02:30 PM
Thanks Dan
Old Sep 16, 2016 | 04:39 PM
I agree with the TTI.....
Hahahahaha.... Ya Iowan... What was that you said????? lol Funny as hell..
Old Sep 17, 2016 | 07:24 AM
Small block A body header is not something I would post on.
Old Sep 17, 2016 | 07:38 AM
Just to tight of a fit? or to much of a pain in the azz?
Old Sep 19, 2016 | 12:45 AM
If you must I would look into block huggers.. Any headers on the drivers side will require the motor to be raised up to remove them... For A STREET CAR stock manifold and a good 2 1/2 dual system will work good
Old Sep 19, 2016 | 05:13 AM
TVLynn, thats probably what I'm going to end up doing, the stock manifold route
Bigiron383
Sep 3, 2010 02:50 AM
Jeeman04
Jan 2, 2010 10:36 AM
THE GOOSE
Sep 6, 2009 06:06 PM
M1 Manifold
May 21, 2009 02:23 PM
LanceFury
May 27, 2008 12:33 PM
