Alternator Question - Over Charging??
Old Jun 16, 2009 | 05:55 PM
mikeynags's Avatar
Junior Member
The following done to a 1970 Plymouth roadrunner.
Installed new Autometer Voltmeter and it shows 14.5 volts at idle, 12.5 @ idle with the lights on. When you bring the RPMs up it goes to almost 16 volts on the gauge. Replaced both the alternator and the voltage regulator at the same time and I am still seeing the same result. Is this just typical for an old mopar or do I have a potential electrical problem? It seems a bit high to me. The built in gauge shows a bit of a charge (10-20AMPS) after you first start the car but once the car warms up the gauge is in the center between "D" and "C". Also, I measure about 12.5 volts @ idle right on the battery and about 14 volts if you bring the RPMs up. Is it a bad gauge or do I have something else going on?
Old Jun 16, 2009 | 05:59 PM
Polaradude's Avatar
see Scott and your other thread.
Old Jun 16, 2009 | 06:31 PM
scotts74birds's Avatar
See you other post
Chaotic cuda
Sep 3, 2014 08:19 PM
BrandonLee4467
Apr 6, 2014 06:30 AM
chlngr1970
Aug 12, 2009 12:16 PM
mikeynags
Jun 16, 2009 08:19 PM
roadrunnerrelic
Nov 7, 2008 06:56 PM
