building a bee!
Old Jan 3, 2013 | 06:19 PM
gojuice4's Avatar
Talking building a bee!
Hello I am from Central N.Y. and a proud owner of a 1970 Superbee 440. I am in need of some help though. what would be the easiest way to hotwire the ignition system to power up the coil so i can fire up my engine? I have the factory style electronic ignition system, engine compartment wiring hooked up, but incomplete dash wiring. I just want to break-in my engine before i worry about anything else right now. any help would be great!!
Old Jan 3, 2013 | 06:35 PM
Welcome aboard.
Old Jan 4, 2013 | 05:35 AM
rickyr's Avatar
Old Jan 4, 2013 | 11:30 AM
Welcome to the forum... Can't help you with the hot wire but sure someone else here can.... Be sure to check out the Mopar of the Month...
Old Jan 4, 2013 | 12:28 PM
You might want to post your question in the engine or electrical section. Might get more response.
Old Jan 5, 2013 | 03:41 PM
bigblock's Avatar
That will take a lil doing but should be no problem.Get a wiring diagram for your aftermarket elec ignition,then wire it up temporary.Jump the starter relay with a screw driver while a helper works the carb lever. Make sure the car cant move"neutral or park".Check all fluids and fire it up.
Bigblock
Old Jan 7, 2013 | 05:52 PM
67hemidart's Avatar
1st make certain car can't move !!! Neutral or park !!!! Jumper from bat + to coil + and jump starter ! This is with no alt as well ! Remove wire to coil to turn off I put a light switch in line so I could shut it down easy . Good luck !! Be safe
Old Jan 24, 2013 | 11:32 AM
challenger's Avatar
prove to us its what your doing we dont want u stealing a car LOLOL just kidden
Welcome hope you enjoy it here
saratooga69
Jul 22, 2009 06:00 AM
crmzendrgone
Mar 18, 2009 09:27 AM
kjwalters4510
Oct 2, 2008 11:47 AM
jane1043
May 11, 2008 10:37 PM
robert garner
Dec 10, 2007 04:38 AM
