Buying a Mopar
Guest
Posts: n/a
Buying a Mopar
Looking at buying a 78 Dodge Aspen SE. Live in western US, no road salt. Pictures look like clean strait car. Is a strait 6 with auto trans. 110k miles. What areas should I be inspecting this car? How is it to swap in a 318? Close to same gas mileage if mild built 318? Price is 900 firm. Good price?
Good luck Oregon Guy. I'm not too knowledgeable on this design, but what little I know and have heard has always said to pay particular attention to the front suspension, especially around the torsion bars mount. Course Mike's car MAY have had most of his problem cause his wife was over 400 lbs too......
floors and truck area are a key area. the whole underside and wheel wells should be looked at as well. If you can find a 318 and tranny to sway in, it would make it a lot easier. You won't get the sa,e kind of mileage though as you will with the slant 6.
![Thumbs up](https://moparforums.com/forums/images/icons/icon14.gif)
welcome OG and for 900.00 bucks who cares if it has a slant six
but like 78 says i would try and find a donor car with a 318 in it so you can take most everything you need to change it over but you will have to go with different mounts and a drive shaft but it would be worth it and i would also look in the trunk and under the passengers side carpet as they sometimes had coolant and windshield leaks and it would rot out the floor but that again is a easy fix >>>><<<< lets see the pic's if you get her ok
![Big Grin](https://moparforums.com/forums/images/smilies/biggrin.gif)
a friend of mine built up a slant 6 back in the day. He would tell me storys about how he was able to keep up and sometimes out run some of the chevys with 350s.
The slant 6s are a tough motor. they can take a pounding and come back for more.
Guest
Posts: n/a
Just bought it
It is a 2door Aspen Special edition. Fairly good condition. Has beginings of some rust cancer in lower quarter panels on rear. About a 4X8" area. Should be able to cut out and weld in some new metel. It is white with red exterior paint with red and white interior. Will post pictures once I get it cleaned up. As anyone had experience of doing body work on these cars?
