CUDDA64
welcome, gas guage look under the car to see if the wire is connected, in these old cars the float will leak and fill with gas and no longer work, ground wire out than turn key to on position to see if needle moves, if so need new float ;tempature guage is a wire that is hooked to the water pump see if the wire is hooked up, always went with after market temp guages
Welcome to the forum please post pics,my fuel guage don't work [gauge good/sender bad] temp guage check wire connection,may be bad sending unit,bad guage or cluster electro board bad.
