CUDDA64
Old Jan 18, 2012 | 06:20 PM
CUDDA64's Avatar
Cool CUDDA64
new member, first mopar car, I have questions. my gas and temp gauges do not work, should i be looking for fuses,ground anything i might need to know?
Old Jan 18, 2012 | 06:56 PM
62Furious's Avatar
welcome, gas guage look under the car to see if the wire is connected, in these old cars the float will leak and fill with gas and no longer work, ground wire out than turn key to on position to see if needle moves, if so need new float ;tempature guage is a wire that is hooked to the water pump see if the wire is hooked up, always went with after market temp guages
Old Jan 19, 2012 | 03:08 AM
Old Jan 19, 2012 | 05:44 AM
rickyr's Avatar
Old Jan 19, 2012 | 10:47 AM
Welcome aboard.
Old Jan 19, 2012 | 03:16 PM
lou3500's Avatar
Welcome to the forum please post pics,my fuel guage don't work [gauge good/sender bad] temp guage check wire connection,may be bad sending unit,bad guage or cluster electro board bad.
Old Jan 20, 2012 | 04:05 AM
Welcome to the forum.... While you are on here be sure to check out the Mopar of the Month contest....
Old Jan 23, 2012 | 06:25 PM
challenger's Avatar
Welcome
