Engine quest heads on LA pushrod length
Old Apr 13, 2018 | 02:16 PM
mopartruckmadness's Avatar
I'm building a 318 LA block with the engine quest heads. I was following an article on hot rod magazine that built this same setup except with a 360 mag block. They said to use 6.900" pushrods but those are about 3/4" short! I also read up about the mopar pushrods that are 7.625" but those are the right length for a hydraulic flat tappet cam and lifters, i am running a hyrdraulic roller cam and roller lifters. Any tips on that pushrod length?
Old Apr 13, 2018 | 02:37 PM
Welcome.
After spending money on machine work and new parts, Rocker Arm geometry/Valve Tip scrub is worth the time mocking up and checking then measuring rod length. I would not go on someone's say so or a guess, valve train geometry is critical on these engines.
Old Apr 14, 2018 | 06:44 AM
I Agree 100%.....
70newport
20
Apr 21, 2016 09:52 PM
Jgriggs29
Mar 8, 2015 11:28 AM
Mr.4spd
Jun 28, 2014 05:34 PM
jascharger
Jul 14, 2010 07:04 PM
azzkikr
Mar 3, 2008 08:45 PM
