Fuel Pump
Old Mar 23, 2020 | 12:29 PM
JackOfAllTrends's Avatar
Fuel Pump
In my 86 D150 I just replaced the fuel pump. One of the old mechanical ones that mounts to the motor block. The old one was leaking really bad when I started the vehicle and would continue for 10-15 minutes afterwards. The new one fixed the leaking problem, however; now the truck has almost no acceleration. It kind of lugs a little bit. I know it’s not a race truck and I shouldn’t anticipate it ever being so, but it has killed my truck once or twice trying to launch from a dead stop. I put some fuel system cleaner in it and that helped for awhile. I didn’t replace the fuel filter. I’m not anywhere close to being a mechanic I just like to work on my own stuff and learn. I know Chevy fuel pumps you have to move the arm a certain way for it to work right but didn’t see that problem with my 318 motor. And the feller I bought it off of has the carb all of the open could that be my issue? Any help is appreciated sorry for the novel on it.
Old Mar 23, 2020 | 02:20 PM
Make sure you got the pump installed correctly and then test the pump for flow and pressure. If thats all good, you have a problem elsewhere....
Old Mar 23, 2020 | 05:51 PM
How do I check the pressure
Old Mar 24, 2020 | 11:35 AM
Here is a general Idea.... >>>>>>
demott128
Aug 13, 2018 09:04 PM
79pw
May 23, 2016 01:57 AM
swordslayer
Dec 1, 2013 10:32 PM
99dakota440
Jun 11, 2012 04:16 PM
Six9DartCustom
Sep 21, 2011 03:36 PM
