My 1972 dodge dart project :)
Old Mar 26, 2012 | 11:08 PM
Josueleyf's Avatar
Hello there . I have a Dodge dart 1972 with a slant six engine . The engine has never been rebuilt and is leaking and throwing a bit of smoke . The thing is that ill be cheaper if i buy another engine instead of doing the rebuildt . I hv been offered a 360 engine that came out from a van and i need from ur wisdom . What will i need to change it ? The motor moints ? Different axle ? Trassmision ? Came from a van ... Different intake and carb ? Plz help ill appreciate it thanks for reading .
Old Mar 27, 2012 | 02:48 AM
What year van? Any way you can get the entire van? I'd take the tranny and wiring with it. Even if the tranny needs a rebuild, its a matched set.
Old Mar 27, 2012 | 04:29 AM
Welcome to the forum... I agree with Tim...... While on here be sure to check out the Mopar of the Month contest... See the sticky for the simple rules and then you can help choose the monthly winner..
Old Mar 27, 2012 | 04:59 AM
62Furious's Avatar
Welcome, the engine and trans are a must your 6 cylinder trans will not bolt up, the rear end is too wide for the Dart. But if you can grab the van it will be nice to have the little parts that you may need or incorperate into your ride
Old Mar 27, 2012 | 05:48 AM
rickyr's Avatar
The oil pan will be the biggest problem, I think a Van will use a truck oil pan and a car oil pan is different
A 360 car oil pan is hard to find and a 318 pan is different than a 360
But they are out there just hard to find.
Good luck
Old Mar 27, 2012 | 06:37 AM
Josueleyf's Avatar
Thanks everyone
Thanks i think the van is a dodge 77 . Oh i didnt kn that about thetrassmision and the oil pan oh well but he also is selling the trans with it but yeah is from a van .
Old Mar 27, 2012 | 08:05 PM
challenger's Avatar
Welcome enjoy the forums
Old Mar 27, 2012 | 08:16 PM
Get Schumacher Creative's slant six to v8 conversion motor mounts. The 360 car oil pan is brand new at Mancini Racing. The tranny from the van should mount up fine. The driveshaft is a different story and if it has a 7 1/4" rear end then they may or might not hold up.
And last but not least Welcome aboard.
Old Mar 27, 2012 | 09:43 PM
Silverick's Avatar
Welcome to the forum!!
Old Mar 27, 2012 | 11:18 PM
6 cyl will definitely have a 7 1/4 rear Won't last long behind a 360 What is the end project going to be ??? Money wise it would be cheaper to rebuild the 6
Prices are just a guesstamate to put the 360 motor in
Conversion mounts $250 Exhaust- headers $600 new drive shaft $250 8 1/4 rear end junk yard $250 new Radiator $150 oil pan $125 oil pump & pickup $50 Used 360 Motor $ ??? New engine gaskets $150 Valve job generic $250 Trans overhaul/ reseal $500 Misc $200 Some will say to not do the valves ?/ The last 318 I did for my van had 100K miles came from an Aspen. I did a quick re do and it ran for another 100K miles
The six if you can do the assembly labor work ??? Should be less than $1000
Old Mar 28, 2012 | 04:06 PM
Josueleyf's Avatar
Well now the 360 is out of the conversation cause the guy soled it lol . But they were charging me 1,800 to re do my slant six , radiator and a quick check out on my tranny . Is it worth it ?
Old Mar 28, 2012 | 05:37 PM
$1800 You are talking about driving in and driving out when it is done !!! Not too bad but ? Depends on what they are doing. the motor can be changed in probably 3 or 4 hours
Old Mar 29, 2012 | 06:23 AM
Josueleyf's Avatar
The guy will change everyhthing from pistons to rings etc . Also he'll re do my radiator , and transs ...is that good ?
Old Mar 29, 2012 | 06:44 AM
Archer's Avatar
J -
I think the real question is what you want to do with the car and how soon you want it (and your budget, of course). Obviously rebuilding the /6 will be the easiest and cheapest. If you're looking for a bit more oomph and aren't in a hurry, then swapping in a V8 is the way to go. The latter will take a lot more time and though.
Has to be your call.
Old Mar 30, 2012 | 11:07 PM
Josueleyf's Avatar
Well ... My first though was to actually rebuild my slant six and mske a performance engine out of it . But what will be good ? A turbo slant or the hyper pack which includes a 4 bbl intake ? thnks everyone
TwistedWrenches
May 24, 2018 07:20 PM
63dartgtcon
Nov 21, 2011 08:26 PM
moparjohnson123456
Jun 14, 2011 01:45 PM
TwistedWrenches
Mar 4, 2009 01:48 PM
chlngr1970
Dec 3, 2008 08:46 PM
