Need help identifing a 68 Charger shifter
Hello all...I'm hoping someone can provide me with some 68 B Body shifter facts.
I have a 68 Charger built in April 68. I'm doing a 4-speed conversion from my console 7277 auto to an 18 spline 833 manual transmission. I will be retaining the console. I know that 68's made a change over from the Inland shifter to a Hurst shifter in early production...around April. I also realize that a console shifter is different than a non-console shifter.
Here's the issue...I recently purchased was was described as a B body 4-speed console shifter. Viewing the photos, I thought so too. Once received I did a little more investigation because the angles seem odd. Some aftermarket sites show replacement versions(that look like the one I bought) as fitting a 68 A body console car. Brewers shows an original 68 with a bend about 3 inches up and a second bend much further up. The item I bought has the first bend up about 6 inched with a second bend almost horizontal and angling towards the driver. The kicker is my Paul Herd restoration guide shows the one I have and makes a note that in early 68 the initial Hurst shifter for the Chargers was also interchangable with A bodies??? Is this true? Were there actually 3 different shifters for an early 1968 Charger? Any help would be appreciated. Steve
not too sure if they were 3 different shifters
I can tell you that that shifter for your car should be the funky looking one right?
it first bends straight to the driver, then up at an angle
Hey Steve, Don't know much about shifters. Just wanted to say Hi and welcome to the forum... I'm sure several here can answer your questions about shifters... Also wanted to bring up a contese we have here each month.. Mopar of the Month... Be sure to check this out.... Each member gets a vote to select the winner....... Be sure to cast your vote.....
jgh68charger/John
Mine definitely did not have the cue ball at the top. You grasped the shifter with your whole hand and it was horizontal as I recall. Maybe some day I will find a pic of what I had. I had the 2 barrel 383 engine and it was ordered at the dealer and optioned as per the build sheet at that time in 1968(summer).
Rumblefish318
Jul 18, 2013 10:14 AM
rcknrolfender79
Dec 4, 2012 05:15 PM
