new to forums. need know how to swap engine.
Old Sep 18, 2013 | 04:17 AM
1973dartswingerdms's Avatar
OK i just got married and my wife bought me a 1973 dodge dart swinger and its a pretty car. but it only has a 225 slant six and its auto so first off i would like to put a 360 maybe 340 if can find right price but i also want to make it manual . i know its going take a lot just need to know where to start ? anything will help would be nice to have parts list and what i should switch first. i know im going have get bigger brakes for the size difference and better rear end i just don't what i need or what size of brakes . no clue what i need for any of it. anything would be a big help.
Old Sep 18, 2013 | 06:04 AM
Save your money for a while It is not cheap maybe $15K depending
Motor mounts from Shumacker www.engine-swaps.com $200 or $200 for a V8 K frame--- LOTS OF INFO TOO !!!!!
A rebuilt HP motor with cam & Aluminum heads $9500 500 hp
if you are going to use an LA style motor get a 318 (340 if you can find one reasonable. smaller main journal than a 360 & it is internally balanced -An advantage with a 4 speed... No special balanced flywheels
A later magnum motor would be good to if you can find a good low mileage used one If you are planning to rebuild a motor ? get a stroker kit with a forged crank 408 CI small block
Trans $3k New kessler 5 speed & drive shaft Maybe a 5 speed from a Dakota
8 3/4 Rear end $1500 with 3.55 gears or 3.91
clutch peddle assembly, 4speed floor tunnel $500
TTI headers $600
This is just estimates for NEW you can cut a lot off by careful shopping used
Old Sep 18, 2013 | 06:24 AM
rickyr's Avatar
Old Sep 18, 2013 | 08:47 AM
inri's Avatar
Congrats on your marriage!
So cool to see that your wife bought you a car! That's awesome!
I happen to agree with TVlynn on this one. If money is no option then disregard the post. But you may want to fix your current car up, make it clean and appealing. And then upgrade. It will cost half as much when you buy someone else's sweet ride.
Just one road you could travel...
Old Sep 18, 2013 | 09:28 AM
Old Sep 18, 2013 | 09:49 AM
slade's Avatar
if u spend 15k on a basic swap you did somthing wrong lol. first go to a junk yard and find a good donor car get the k frame rearend totsion bars ect even engine and trans if its what your looking for
Old Sep 18, 2013 | 09:52 AM
slade's Avatar
were r u located btw
Old Sep 18, 2013 | 05:21 PM
Welcome to the forum... Be sure to check out the Mopar of the Month contest.... You have quite a project ahead of you.... Keep us posted on your progress...... We love projects!!!!
Old Sep 18, 2013 | 05:36 PM
Old Sep 18, 2013 | 05:55 PM
Welcome aboard.
Old Sep 18, 2013 | 08:37 PM
thanks all for the welcomes and the advice . im from cali well im stationed there at the moment im deployed. ok so to put a 360 in the car i need a new k frame ? or is that just the best way to do it? when i get back to the states ill put up more pics of the car and keep updates to the progress of the project. and im statring with about 5000$ what should i do first ? i dont need the fasted car i just want to be able to spin the tires if i wanted to . and on that i have read a little on keeping the 225 and just rebuild and add turbo whats comments on that?
Old Sep 18, 2013 | 10:02 PM
slade's Avatar
the /6 is a strong strong engine and me and my brother have discussed at turbo /6 . lots of possibiltys there ur gunna wanna find 4 bbl intake and carb for one. and like i said find a v8 with the stuff u need like the k frame torsion bars rearend ect it will make it alot easier on u
Old Sep 19, 2013 | 12:06 AM
ok so if i keep the slant six and just fix it up maybe boar the engine and a turbo . could i get up to 300 hp ?
Old Sep 19, 2013 | 10:36 AM
slade's Avatar
hell yea. i think theres a site called slantsickness if its still around check it out. id put the boost right to tgat engine
Old Sep 19, 2013 | 01:29 PM
First thing I would do is check the rear end You probably have a 7 1/4 it will not last long even with a hopped up 6.. If you are lucky you may have a 8 1/4 which would be fine.. If going to a 360 ? with a 4 speed I would look for a 8 3/4 rear
K frame swap = use factory V8 mounts
Old Sep 19, 2013 | 03:35 PM
lou3500's Avatar
Welcome to the Forum, I personally would fix the slanty, if you wanted a v8 car in this market you should have looked for one the money you'll spen you could have bought one, I'm sorry for being up front but you'll spend more money and labor than what it's worth. There are a bunch of Slantys being built both turbo, supercharged and with blowers!!!!!!!! I know of someone with a turbo duster he has a 360 sitting in his garage but built the slanty!!
Attached Thumbnails new to forums. need know how to swap engine.-mopars-merits-2012-071.jpg
Old Sep 19, 2013 | 08:04 PM
moe7404's Avatar
yep tvlynn is right the 7 1/4 rear is good for nothing. i bought 1 new car 1984 ply fury, 1 new truck 1977 D100, with a 7 1/4s. neither lasted more than 80,000. with low power engines.
Old Sep 19, 2013 | 08:34 PM
Silverick's Avatar
Personally, I have always been a V8 fan and didn't think too much of a slant 6 for performance though I have heard of a few that supposedly ran pretty good....
A few months ago, I went down to San Jose to pick up an 8 3/4 3rd member for a friend and I met a guy, all that he has is slant 6s, and apparently they're fast! He opened the hoods on a few of his A bodies and they all had at least one single 4bbl carb on an intake manifold that this guy had engineered and cast, or had cast, with his name cast into it! With an intake, a set of headers and a cam these slant 6 sounded bitchin'!!
One of his cars was a mid sixties Valiant with a Barracuda front end on it, which actually looked very good and had a few stories, too!
I left his house with serious respect for those lowly slant 6s! lol
Old Sep 20, 2013 | 12:03 AM
slade's Avatar
a bigger rearend will be required thats a must and you might aswell go.posi.
i hope you go with a slant6 it will be a really cool build.
silverick. my brother has a 4 bbk intake for a slant6
Nathan talley
Feb 19, 2014 02:24 PM
DustinHeck
Oct 15, 2013 01:21 PM
gearheadmike
Aug 15, 2011 04:22 PM
piperman60
Jan 7, 2010 05:52 PM
66coronetgirlie
Oct 30, 2007 11:16 AM
