New to MOPAR
Old Aug 25, 2011 | 03:57 AM
tyler_hagger's Avatar
New to MOPAR
Hi, I just recently purchased my first (running) classic MOPAR, a 1965 Plymouth Fury III. It's the first daily driver I have without fuel injection and a computer. I'll admit I know very little about these old cars, which is why I'm here. I'm wanting help and advice in adding more power to a bone stock 383 two barrel. Friends told me about a kit from 440source to bore it over, but I've also considered a dual quad setup. Any suggestions would be much appreciated. Thank you.
Old Aug 25, 2011 | 04:32 AM
Just remember that with more power from the motor, you may need build up the tranny and rear axle to handle it and the brakes to help you stop better. With a 383 though, there are may ways that you can build power.
Old Aug 25, 2011 | 06:11 AM
rickyr's Avatar
Old Aug 25, 2011 | 07:25 AM
Welcome to the forum.
You said this car is your daily driver? Do you really want to start modifying it if it is?
Old Aug 25, 2011 | 07:54 AM
Silverick's Avatar
Welcome to the forum!
There are a few fairly straight forward things that can be done to your 383 2bbl, that will wake her up. The first is a set of dual exhaust. This was the first modification that I did to my Fury. She sounds good and there is a subtle difference in power.
Old Aug 25, 2011 | 01:17 PM
MercuryDon's Avatar
I'd stay with a single carb if its going to be a daily driver. A good dual plane intake(Performer RPM) and 650-750 cfm carb along with dual exhast would be my recomendation. You may also want to up cam it with a mild performance cam along with new lifters and timing chain & gear set. Also go with a mopar performance ignition.
Old Aug 30, 2011 | 03:33 AM
Hey Tyler welcome to the forum.. I see you are already getting ideas and suggestions about your ride. A lot of info here and all are willing to share.. One other thing is when you are on here be sure to check out the Mopar of the Month contest... See the sticky for the simple rules and then you can help choose the monthly winner.....
6_7_G_T_X
Feb 4, 2014 06:41 AM
Mopar4Llfe
Apr 4, 2013 04:15 AM
69Ronrunner
Feb 19, 2013 05:13 PM
leo_tposha
Feb 19, 2013 06:25 AM
privera4
Mar 5, 2010 04:08 PM
