newbe 85 d150
This is just my best guess about the size.
When you get the truck back you should take some measurements. Measure what the bolt pattern is, and how much backspacing your current wheels have. Also turn them full lock both ways and take some measurements from the inside of the tires to the frame, suspension, and steering parts, just to give you an idea about how wide you can go
Guest
Posts: n/a
thanks for the replys my bolt patern is 5x5.5 same as new dodges and i know people have put rims from newer trucks on there d150 just dont know if they used spacers or not and if they did what size they used, the only suspension mod i may do is lower the truck some, wont know until i get the wheels to see how it looks shop called and said it was done today he finished it on easter what a guy so ill take pics and post tomarrow if i get time still wont be done though still gotta get new chrome and glass but the color is a pearl blue with metal flake in the clear
IF you can find the backspacing of the wheels that you want, compair them to the wheels that are on there now. That will give you a good understanding about how they will fit.
