Relocating the battery to the trunk 69 Roadrunner
Guest
Posts: n/a
I'm relocating my battery to the trunk I have the kit from Jeggs. My question is under the hood I presently have a 3 ft 6 guage red wire going from the positive battery terminal to the starter relay on the firewall. Now will I need to run a new 6 guage wire from the trunk to the starter relay, or is there something else I can do? Also what exactly does that wire do, does it give power to the relay? If it does, can't I just connect that same wire that came off the battery post, to the new postive cable the will connect to the starter? If I do have to run a 6 guage from the trunk does it have to be a 6 guage the local auto parts stores do not seem to carry it it stock. Thanks any suggestions will be greatly appreciated. MOPAR ON!!!
the relay gets its power from the battery and sends it to the ignition starter. The ignition switch tells the relay when to send power to the starter and the coil to start the motor. About how many feet of cable do you need to go from the battery in the truck to the relay?
You might have to get a 4 gauge wire instead as the longer the cable is the more power you can lose through it. Also, when you do get a cable, get a cable that has a lot of very small wires in it, like speaker wire. Electricity travels on the surface of wires, not through them.
I moved the battery to the trunk in my 69 Coronet. I used a Taylor kit with 1/0, stranded diameter positive cable. I installed a remote on/off as per NHRA requirements. I also added an inline fuse in the trunk as a safety measure. What I am finding is that the 150 AMP is blowing sometimes when trying to start the car. Not sure if there is a charging problem or the old battery was just not capable of providing enough juice. I have replaced the battery and will be testing the starting function soon. I am just confused about the fuse 150 AMP fuse blowing. I thought the 1/0 wire would allow the juice to flow easily from the trunk to the engine compartment. I have not run a ground from the battery to the front of the car. I am thinking about it. The ground connection in the rear is connected to the rear rail on the passenger side. Once the car is running there are no electrical issues that I know of. Will also get the alternator tested. It is a Caddy unit, 1 wire system. When I up the RPM the volt meter kicks to about 14 volts. The old AMP meter burned out and almost took the car with it, so I converted to the Volt meter.
There is my experience. Any comments/suggestions welcomed.
426HemiHammy
Apr 29, 2011 06:15 PM
and yourself
