ricky Richter new member
Old Feb 4, 2011 | 07:22 AM
rickyr's Avatar
Hi,
I am new to this forum
My name is Ricky Richter
I have a 1968 GTX and a 1993 Viper
I work @ Holley Performance Products
In Tech. Service
So if any of you have any Holley ???
I might be able to help
THanks
Old Feb 4, 2011 | 01:44 PM
Barfly needs to talk to you about his 340 V8.
Old Feb 4, 2011 | 02:48 PM
Welcome to the forum... I'm sure you will be answering a lot of questions... Looks like you have a couple very nice Mopars. Be sure to check out our Mopar if the Month contest... See the rules in the stick on our home page.... Each member gets a vote and can nominate and second any car but their own... Then you get a vote and the car that gets the most votes wins....... Who knows maybe one of yours will be in the running.........
Old Feb 4, 2011 | 07:19 PM
challenger's Avatar
Welcome Ricky
Old Feb 4, 2011 | 11:41 PM
Silverick's Avatar
I welcomed you in another post but, will rewelcome you!
That's great information. Thanks
I have Holleys on both my MasterCraft and my '70 Formula 400.
You'll find that this forum has a pretty solid group of members. Rick
Old Feb 5, 2011 | 08:02 AM
rickyr's Avatar
Thanks for making me feel welcome
I will answer all the Holley questions I can
Other brands of Holley are Hooker headers, Flowtech headers, Nitrous Oxide systems, Earls plumbing,Weiand intakes, water pumps and Superchargers
Thanks
Old Feb 7, 2011 | 07:37 PM
Archer's Avatar
Ricky -
Thanks for the good info so far!
Like to throw this at ya.
Basic specs, 69 440, 30/over, 10:85:1, 465"/280 degree ISKY cam, 1 7/8" Pri Hookers, 3000 stall TQ, 3.23 rear, 4200# car. 850 DP atop an old style Edlebrock Torker. Vac at idle in gear, 10-11".
Based on what you said, I should be running a 5.5 power valve.
Currently have a 6.5 PV and everything seems to be running fine, worth changing?
Sorry, nowhere to run the 1/4 tests you described, these days.
And... the carb is a 1980 vintage, what would I have to replace to get the PV backfire protection? I thought it was the throttle body or a base plate?
OK, last question. As I said, seems to be running pretty well, any reason to "upgrade" to a newer Holley carb?
Thanks,
Old Feb 8, 2011 | 05:57 AM
maddawg57's Avatar
welcome
Old Feb 8, 2011 | 06:03 AM
rickyr's Avatar
I do recommend a 5.5 PV part # 125-55
It might be OK with a 6.5
but to do the best I would change to a 5.5
You can get part # 125-500 to add the power valve protection to the carb you have
it is a check ball and spring it will come with the right size drill bit and instructions
Thanks
Old Feb 8, 2011 | 06:07 AM
Archer's Avatar
Ricky -
Thanks, it's on the list for the spring (if this snow ever melts...) Any thoughts on the modifying the carb to prevent backfiring from blowing the valve? Only happened once, but if it's an easy fix, might be worth it.
Thanks again,
Old Feb 8, 2011 | 06:18 AM
rickyr's Avatar
Thanks
Old Feb 8, 2011 | 06:41 AM
Archer's Avatar
Ricky -
Very cool, thanks!
Old Feb 8, 2011 | 07:45 AM
rickyr's Avatar
part # 125-500 will be in the ball park of $ 15.00
Thanks
Old Feb 9, 2011 | 05:40 PM
Buffalojoe426's Avatar
Welcome to the forum!
Old Feb 13, 2011 | 03:40 PM
rickyr's Avatar
welcome
bremereric
Apr 6, 2012 09:01 PM
ricky d
Feb 28, 2011 04:11 PM
rickyr
Feb 21, 2011 02:37 PM
rickyr
Feb 3, 2011 07:31 AM
Sovereign
Sep 8, 2010 11:48 AM
