Sudden loss of oil pressure
Old Aug 6, 2018 | 04:28 PM
flashman's Avatar
While driving home, my 1992 Dodge Dakota with a 3.9L suddenly loss oil pressure according to the gauge. Now the engine won't start.
There are no leaks.
Can anyone point me in the right direction to troubleshoot the problem.
Old Aug 8, 2018 | 06:30 PM
Sounds like the oil pump pick up in the oil pan fell off. And now the engine might be frozen up?
Old Aug 9, 2018 | 03:55 AM
flashman's Avatar
Hey Racer, thanks for the reply. The engine does turn over so it's not siezed
Old Aug 9, 2018 | 10:18 AM
flashman's Avatar
I just checked the distributor and it rotates as the engine is cranked, so it can't be the timing chain
Old Aug 10, 2018 | 05:04 AM
Got spark ?
Old Aug 10, 2018 | 05:07 AM
flashman's Avatar
No, apparently, the computer is prohibiting circuit due to no oil pressure
Old Aug 10, 2018 | 05:11 AM
In that case. it appears that you may need to check and see if the oil pumps drive shaft has broken or the pump might have failed?
Old Aug 10, 2018 | 05:13 AM
Or look at a wiring diagram and see if you can bypass the oil switch and check it for spark. and if you then have spark? at that point you can use a manual gauge to check for oil pressure.
Old Aug 10, 2018 | 05:20 AM
flashman's Avatar
That's pretty much what I figured. Just before the truck died, there was a high pitched squeal. I'm leaning more towards the drive shaft, because the oil pressure was perfect before the engine died.
kcunningham1999
May 4, 2017 05:02 PM
tattoopat
Oct 29, 2014 06:25 PM
art cee
Aug 19, 2013 03:54 PM
Amos 33
Jan 29, 2012 05:33 PM
haffjones
Aug 2, 2010 05:13 PM
