Torqueflite 727 question
Old Aug 24, 2009 | 09:36 PM
Cracocuda's Avatar
Unhappy Torqueflite 727 question
I have a dilema in my e-body project. When I remove the 318 motor and the transmission from my Barracuda I notice that this transmission is longer than other 727 Torqueflite that I removed from a donor Barracuda. The difference is about 6 inches or more. Also the driveshafts have different measurment to compensate.They also have different marking numbers above. The short tranmission has 452-7, the longer transmission has 844-6. Does this number means something?. To those who know more of this Torqueflite transmissions,does this numbers means something?. I thought that all small block Torqueflite 727 transmissions where the same. Longer trans maybe from a Mopar truck? Any help in this dilema will be appreciate. Oh I forget to tell, longer transmission is from a 70'Barracuda and the shorter is from a 72'.
Old Aug 25, 2009 | 05:38 AM
64fury's Avatar
What engine is in the donor car?
Old Aug 25, 2009 | 05:57 PM
theomahamoparguy's Avatar
that shorter trans must be a 904 trans [is it about 5-6 inches shorter]
thar is the only thing I can think of. Do the transmission pans look different?
Old Aug 25, 2009 | 06:59 PM
Cracocuda's Avatar
A 318
Old Aug 25, 2009 | 07:08 PM
Cracocuda's Avatar
They look the same size,but I did not measure them to compare.
unclehulka
24
Sep 27, 2013 03:28 PM
lonestar87
May 22, 2009 04:24 PM
Jonsalter74
May 13, 2009 03:09 PM
hubcap
May 28, 2008 05:24 PM
hubcap
May 6, 2008 06:26 PM
