transmission/tail-end
Old Aug 7, 2012 | 04:18 PM
maskichris's Avatar
Exclamation transmission/tail-end
[U]hello, does anyone now if you can change the tail-end of a transmission[U]
i have a 99 ram conversion van i changed the filter and when i opened the pan there was broken bands laying inside it , i found a used transmission but it has the wrong tail-end . can i change it and how difficult is or would it be better to pay to have it changed ? are they sealed units or would it not be any good either
thank you
Old Aug 7, 2012 | 09:44 PM
Without knowing exactly what you have ? It's not that simple. The tail shaft on the later transmissions has the overdrive unit. It sounds like you would also need to change the output shaft?? Total rebuild time !!
Old Aug 8, 2012 | 02:42 AM
What is the "new" tranny out of?
Old Aug 8, 2012 | 06:07 AM
rickyr's Avatar
Old Aug 8, 2012 | 11:23 AM
maskichris's Avatar
update to tail-end trannie post
sorry, the transmission is from a 1999 dodge ram conversion van, 318 motor auto with overdrive, the new used trannie we got is from a dodge ram p/up with the 318 . the bell housing appears to be the same but the tails are same except speedo in different area on tail section.
Old Aug 8, 2012 | 12:25 PM
ARE the pans the same ? Pictures would help. If the speedo drive is in a different location ? I would suspect the gear drive on the output is different ??? COuld the truck have been a 4 wheel drive ??
Old Aug 10, 2012 | 01:56 PM
maskichris's Avatar
idk what it came out of exactly except it was a dodge ram 1500 p/up they appear to be the same but the numbers are different on the bell housing and tail end the original is 064-11, 25100-16 the new one is 064-1, 17905-8 the first number is the bell housing the second is the tail end number like i said it is same except the original doesn't have the sensor on the tailend same length and size do the numbers mean anything , are they interchangeable the tailends that is. need good advice do not want to take apart until i now for sure [do not want to brake it] yes the pans are the same
Old Aug 10, 2012 | 01:58 PM
maskichris's Avatar
thank you, any ideas on my post
Old Aug 13, 2012 | 03:07 AM
It sounds like they are the same so the tail shafts should be able to be changed. The only issue is that both trannies need to be disassembled IIRC in order to change the rear output shaft.
Old Aug 15, 2012 | 08:08 AM
Gorts 5th's Avatar
if the only problem is the location of the speedo gear is there any way too use the original cable just re-rout it
too open an old trany is risky the seals could be hard and if they rip you got to replace em/rebuild the trany anyway and since your going to swap output shafts why don't you just rebuild the original if i remember correctly you got to disassemble the entire trany anyways to remove that shaft and the input shafts could be different lock-up vs non-lock-up
if it was me i would rebuild the original its not that hard
Old Oct 26, 2012 | 12:21 AM
Canfield's Avatar
i just went through this with my 64 push button. same scenerio. and same outcome. the tailshafts stay with the tailhousing. and the tailshaft is the last part to come out. ya may as well rebuild one. the kit's are the cheapest part if ya put a value on your time. and you know what you have in yours. don't trust the other one just cause it doesn't have metal/babbot in the pan...
Old Oct 26, 2012 | 06:21 AM
Gorts 5th's Avatar
Smile
thats right if you got the manual i usu automatic transmission service group just take your time have a well organized work area clean not clutered with stuff all the parts on the 727 are removable with limited special tools snapring pliers and the such
dodge_dart69
Mar 25, 2014 12:57 PM
mach3107
Feb 9, 2011 10:46 AM
Nomadci
Jun 23, 2010 07:22 PM
66monaco
Jun 26, 2008 06:43 PM
azzkikr
Feb 21, 2008 04:36 PM
