Holley 2210 Carb, stalls off idle
Old Nov 6, 2009 | 08:40 AM
TimN8er's Avatar
Exclamation Holley 2210 Carb, stalls off idle
Does anyone have experience with this carb. It was rebuilt by a shop. I installed it and did the timing. Im able to let it idle but as soon as i accelerate it dies, if i hold the choke partially closed i am able to accelerate. let it go ad it dies. I closed off all vacuum hoses to ensure i did not have a vacuum leak. even sprayed carb cleaner around the intake. So now i am not sure whats up.
Old Nov 9, 2009 | 11:02 AM
TimN8er's Avatar
No body at all with any thoughts.
Old Nov 9, 2009 | 02:41 PM
theomahamoparguy's Avatar
im gonna venture a guess and say that the idle is set too lean or maybe possible accel pump problems.
Old Nov 9, 2009 | 02:48 PM
scotts74birds's Avatar
Is the accelerator pump functioning? When you move the linkage off-idle does the pump lever start moving immediately like it is supposed to? Ya dig?
Old Nov 29, 2009 | 08:16 AM
TimN8er's Avatar
Ok well thanks guys, I took the carb apart and it had some crap in it. Not sure how it got in there so I cleaned it out. Cut the fuel line off before the pump and added a new line and placed it in a gas can. turned it over to pump out what ever was in the pump into a clear jug untill it came out clear. then ooked up the carb. It ran much better how ever i had to keep the choke closed withmy hand to keep her running. I was able to limp it from storage to home. Burned a tone of fuel. Ive decided to rebuild the motor and since its a 76. Tried all your suggestions played with the misture never improved.
Thanks again.. Ill keep it posted as i do more work.,
Old Feb 7, 2010 | 05:49 PM
dodge610's Avatar
Member
Does it have a power valve in it mine acted the same way on my 77 i tried every thing then a buddy said lets change the power valve ran like a top.
Old Jun 12, 2012 | 06:15 AM
TimN8er's Avatar
Well I never did find the problem, But I think it may have been more of a timing issues. I pulled the motor and the timing chain had alot of play. Its possible it skipped a tooth but who knows, The power valve was new at the time and still acted the same. Carb was rebuilt for the 3rd time
Old Jun 13, 2012 | 10:48 AM
Gorts 5th's Avatar
it sounds like power valve wats your idle vacuum if its 12 hg you'll need a 6.5 power valve the rule is half of idle manifold vacuum 14 hg 7.5 power valve, the rebuild kit most likely contained the wrong power valve
Old Jun 20, 2012 | 06:13 AM
TimN8er's Avatar
Well thanks for the added info, But the vehicle is now gone along with the problem. Ill keep it in mind if i ever encounter another..
plux92
Aug 12, 2016 07:12 AM
mopars again
Dec 15, 2014 11:21 AM
chlngr1970
Dec 9, 2013 05:49 PM
Henrius
Nov 11, 2009 06:51 PM
YellowTruckOfAwsomeness
Feb 24, 2009 01:19 PM
