over heating problem
Old Jun 14, 2022 | 06:03 PM
1956dodge318's Avatar
hi just building a 56 dodge 1/2 ton,i put a 318ci w/ 727 auto.Im having a problem with it getting hot,seems not circlating. i put a 195 thermostate then a 180,still when i take rad cap off,no circlation.
Old Jun 14, 2022 | 07:21 PM
Are you using a new water pump or an old one with many miles and years on it? Mopar water pumps have had a problem with impellers rotting off making them inept. So pull the pump and have a look….
Old Jun 14, 2022 | 07:23 PM
Archer's Avatar
1956 -
Wouldn't "no circulation" imply a bad water pump or blockage some where?
Since you changed the t-stat, odds are it's not stuck, unless they were both Mr.Gasket t-stats.
You could/should change the water pump, and get an IR thermometer and trace the water flow, looking for a drastic change in temp or a reading that doesn't make sense.
Jim's 36
May 31, 2022 08:46 PM
lancer61
Feb 15, 2016 09:05 AM
Magoo
Nov 10, 2015 04:18 AM
CantRamItDodgeIt91
Non-Mopar Tech Questions
Sep 20, 2009 08:53 PM
jane1043
May 20, 2008 07:32 PM
