Pump Noise
Pump Noise
I have a 02 Cruiser and after making a U-turn, I notice a whine coming from under the hood. Is this the PS pump and if so why does it whine after the turn is completed and the vehicle is traveling in a straight line? Thanks.
Possibly low on fluid, have you checked that?
Not sure, but a whacked out theory i came up with, if the valve in the rack got stuck one way, then there would be pressure to one side, nothing on the other. But then I guess that'd make it hard to steer and pull you in one direction or another.
I vote low fluid.
I vote low fluid.
