360 carberated cheap build up
Old Apr 24, 2011 | 09:29 AM
dodge6890's Avatar
i have a 360 motor in a dodge sportsman camper that im looking to get a little more power out of without spending to much money in the process.
Old Apr 25, 2011 | 12:21 AM
Maybe headers and a good 4bbl carb do you have a 2 bbl or the thermoquad manifold?
Stick with a dual plane intake, 600 cfm carb and a mild cam something like 268 degree
Old Apr 25, 2011 | 02:41 AM
If you don't want to tear into the motor too much, then go with a 4barrel carb, intake manifold, headers, Sure Grip in the rear axle and possibly a HD shift kit for the tranny (Assuming its an auto).
Old Dec 28, 2011 | 05:55 PM
PK1's Avatar
PK1
Another vote for Headers for sure. Get Tri-y style to get the biggest bang for the buck out of a lower RPM motor. Then a quality aluminum dual plane and a carb.
Old Dec 28, 2011 | 06:10 PM
If it's a stock distributor a recurve and controling your initial advance could help for almost no money. Lots of info on the subject if you look.
Old Jan 22, 2012 | 09:58 AM
bboogieart's Avatar
Are you leaving it in the motor home? Mine came with super long tube headers. I will be pulling it for something else and using the headers in my van. It also had a 2 bbl. The thermoquad would be better.
The earlier posts said it all, I really can't add much. Maybe this might help. Depending on where you live, I have found that many junk yards out in the rural areas still have some older stuff laying around and a little yard searching can be fun and yeild many good parts. I recently got a windsheild ( 70's p/u) a 4 bbl intake (318 dakota) and a pair of rims (14" five slot off the same dakota) for 50 bucks.
swalker5906
Oct 22, 2009 10:13 PM
joel
Feb 22, 2009 06:51 PM
shlep1968
Nov 22, 2008 01:32 PM
70cudas
Nov 13, 2008 10:22 AM
7thgeneral
Jul 25, 2008 09:44 PM
