is this a bad idea?
Old Dec 8, 2008 | 11:54 PM
360s are a pretty tough motor. If you do deside to go and do it, then when the heads are off, take a look down into cylinder #8 and see what the cylinder walls look like. It could be a ring that is causing low compression or the head (gasket, valves, etc.). I say do it, but in the end, it's your vehicle and your choice.
Welcome to the forum.
Old Dec 9, 2008 | 01:21 AM
rr69half6bbl's Avatar
welcome to the site. yes, definitly do the heads, itll wake the 360 up. like 78 says, check that cyl. if theres no ridge, and the walls arent scraped up from a bad ring, then just cap it and run with them.
Old Dec 9, 2008 | 04:36 AM
mr340's Avatar
Like they said, tear down the top end, inspect ALL THE CYLINDERS, put on the new heads and let 'er rip! As long as there is no lower end knocking now I don't think you'll have much of a problem. Your compression loss in #8 could be thru a valve that is not seating properly or another issue with the existing head. Have at it!
Old Dec 10, 2008 | 04:08 AM
Commando's Avatar
Do you have the space to pull the pan out? If so I would think you have enough room to do that.
Old Dec 11, 2008 | 06:08 PM
challenger's Avatar
welcome to the forums stickshifted as everyone says go ahead and do it and check it all out , if nothing else you can always put the old set back on with new H gaskets but ill bet that motor is still good to go with a new frech set of heads, you have to have a pretty high milage engine that wasn't taken care of to hurt a 360, ive redone heads on one of my 340s with 260,000 miles on her and it never missed a beat and them 360s are built just as strong but if you decide to go ahead and do it make sure you put some good oil in her like the valvoline vr1 or the high milage valvoline oil with alot of zinc in it and i would reccomend using some lucas HD oil stabilixer also and you will be good to go for some more extreem milage
Old Dec 12, 2008 | 05:21 PM
Commando's Avatar
The stabilizers help prevent the fuel from breaking down which it does a lot faster with the ethanol in it today.
Old Dec 12, 2008 | 05:50 PM
challenger's Avatar
i would think that you might just have a sticky valve that might be giving you a problem in only one cylinder so id just change out the heads if your still wanting to and make sure you do a visual in all the cylinders like all are saying and maybe run some engine clean in the oil (oil supplement) and run before an oil change and see if there is any differance with the compression before you start tearing it apart , it could just also be a sticky ring which the cleaner will help free up, but ill let you make the call
Old Dec 12, 2008 | 05:52 PM
challenger's Avatar
p.s C means the oil from breaking down so quickly
Old Dec 12, 2008 | 06:24 PM
Commando's Avatar
Yes, thanks, I was thinking about Stabil and the fuel stabilizers, and not Lucas which he was talking about.
Old Dec 12, 2008 | 06:55 PM
challenger's Avatar
Hey C its all good and the lucas oil is a oil stabilizer which has no sulphur or chlorine and no teflon in it that im one that doesn't really like the teflon and it helps eliminate dry starts and it helps seal the worn cylinders and it helps stop the thermal break down of the oil
Old Dec 13, 2008 | 05:40 AM
Originally Posted by stickshifted
aye thanks for the welcome.
the guys on the myspace mopar forum recommended against since im putting "new" heads on a motor thats seen a lot of miles.
Myspace morpar guys. phst, a lot of people on there give bad advice, thats why I don't waste my time with them. What is the worse that can happen with a fresh set of rebuilt heads? Better flow? Better throttle responce? the fact that you now have some more power? Yeah, those all sound like bad reasons to me.
Do the swap and you will be in love, trust us, the people that live, eat, sleep, breathe and poop mopars!
As far removing the piston in the motor...... It can be done but take a lot. You may be able to rotate the crank enough to squeeze it by. If not then you will need to pull the motor. It is just too much hard work to pull the crank in the vehicle.
Old Dec 13, 2008 | 05:51 PM
challenger's Avatar
AGREE 78 and for the piston i think he just wants to pull just that one but if it were mine i would just look at it then go from there but im still for using cleaner first if thats the case but im sure its not ,,, it needs the heads changed and a good OIL and run the crap out of it
Old Dec 17, 2008 | 03:46 AM
I wouldn't use WD-40. The WD stands for water diluted. Clean up the pistons with kerosine (I think I murdered the spelling on that one) and use plenty of oil when putting it all back together. If you plan on re-ringing the pistons, then you are going to want to install all new bearings. If you are going that far, then pull the motor and make it easier on yourself. Pull the cam shaft out as well and install new cam bearings and a mild purple shaft cam. You will be very happy with it then. Plenty of power, strong and realiable. You just have to make use that you break in the motor properly. If the stock cam looks good, I would even just throw it back in to same yourself some money.
Old Dec 17, 2008 | 04:51 AM
Commando's Avatar
I agree with 78, by building up or fixing certain things you are going to expose your weak points, and you can avoid it by looking at those bearings, cam, and crank. If you are going to do all of them I would recommend pulling the engine and putting it on a stand so you can rotate it over.
Old Dec 17, 2008 | 08:06 AM
It makes it much easier to work on, take measurements and torque everything to spec. Plus you can paint it while you have it out.
Old Dec 23, 2008 | 04:29 AM
I would only put in Champion plugs in a mopar motor, especially the LA SB and BB. Run the gap at .035, thats what it should be. No higher than about .045 though if you have some ignition upgrades.
What color is the smoke?
Old Dec 23, 2008 | 02:02 PM
i only run champion plugs either
i have the gap at .35
Old Dec 31, 2008 | 04:01 AM
  #25
Your plug gap should be at .035 gap. Having the gap open more will create a larger spark to burn more of the fuel/air. It sounds like your plugs are good.
As for the black smoke, hat could be too much fuel at the beginning or carbon build up. How many times are you pumping the gas before you fire it up? You should be doing it only aout 2-3 times.
As for the grayish-white smoke, I'd be willing to bet that you have a coolant leak somewhere. Either a head gasket or a head.
The 190* thermostat is good for that motor. I wouldn't change it unless you do some big upgrades (cam, alum heads, pistons, boring, etc).
I wouldn't change your timing just yet. Even if you have a larger size gap plug, you shouldn't have to change your timing.
Zach8200
Apr 19, 2009 09:18 AM
blue 68 gts
Feb 26, 2009 02:02 PM
66sportfury
Jan 22, 2009 10:07 AM
moparfection
Dec 16, 2008 07:16 PM
Sanitarium
Mar 20, 2007 11:39 AM
