Auto Club Finals Pomona
Old Nov 11, 2010 | 04:05 PM
Thu, 11 Nov 2010, 05:32 PM
Pro Stock Qualifying Notes, Session #1
By David Gerard
POMONA, Calif. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 46th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Bob Glidden Runs 6.666/207.34, Now #1
1:51 p.m. Weather conditions: air temperature 73 degrees, relative humidity 24 percent, barometer 29.07 inches, adjusted altitude 2,232 feet, track temperature 96 degrees.
Funny car burnout for Glidden on his single to start the session.
A career best ET and MPH to set a strong mark for the rest of the field. Strong 1.005 sixty foot time.
Bye's incremental times: 60ft-99.999 sec., 330ft-99.999, 660ft-99.999/000.00 mph, 1,000ft-99.999.
Left Lane: Gordie Rivera No Time, Now #3
Right Lane: Dave Connolly Runs 6.615/209.23, Now #1
Rivera leaves before the green and will not get an ET.
Strong pass for Connolly in the MAV-TV Cobalt.
Dave Connolly's incremental times: 60ft-0.992 sec., 330ft-2.780, 660ft-4.261/166.52 mph, 1,000ft-5.538.
Left Lane: Erica Enders Runs 15.088/56.26, Now #4
Right Lane: Vinnie Deceglie Runs 6.572/210.67, Now #1
Enders shakes and falls back. She must have broken something, as the car just makes the turnout.
A good looking pass for the Mountain View Avenger with near career best performance to take the new top spot.
Vinnie Deceglie's incremental times: 60ft-0.982 sec., 330ft-2.753, 660ft-4.229/166.72 mph, 1,000ft-5.501.
Left Lane: Ronnie Humphrey Runs 6.570/211.26, Now #1
Right Lane: Larry Morgan Runs 6.834/207.18, Now #5
Morgans Mustang moves out of the groove and towards the wall and he drives it on through.
Big MPH for Humphrey on a great looking pass into the top spot.
Ronnie Humphrey's incremental times: 60ft-1.002 sec., 330ft-2.769, 660ft-4.237/167.78 mph, 1,000ft-5.505.
Larry Morgan's incremental times: 60ft-1.012 sec., 330ft-2.916, 660ft-4.445/162.45 mph, 1,000ft-5.744.
Left Lane: Bob Yonke Runs 6.607/209.75, Now #3
Right Lane: Warren Johnson Runs 6.694/209.49, Now #6
Johnson's car is all over the track at the green with big left and right moves down the track.
Strong pass for Yonke, well into the current top half of the field.
Bob Yonke's incremental times: 60ft-0.994 sec., 330ft-2.772, 660ft-4.254/166.46 mph, 1,000ft-5.531.
Warren Johnson's incremental times: 60ft-1.011 sec., 330ft-2.839, 660ft-4.335/165.25 mph, 1,000ft-5.617.
Left Lane: Kurt Johnson Runs 6.616/209.82, Now #5
Right Lane: V. Gaines Runs 14.605/59.14, Now #9
In near a rerun of Johnson, Gaines' Avenger moves hard off the line towards the wall. He gives up early and motors on down.
Clean pass for Johnson.
Kurt Johnson's incremental times: 60ft-0.997 sec., 330ft-2.782, 660ft-4.264/166.15 mph, 1,000ft-5.540.
Left Lane: Rodger Brogdon Runs 13.970/59.28, Now #10
Right Lane: Johnny Gray Runs 6.638/208.97, Now #6
It's the left lane this time, as Brogdon's GXP almost crosses the centerline right off the line.
Clean pass for Gray to tune to tomorrow.
Johnny Gray's incremental times: 60ft-0.991 sec., 330ft-2.793, 660ft-4.280/166.11 mph, 1,000ft-5.560.
Left Lane: Ron Krisher Runs 6.569/210.60, Now #1
Right Lane: Jeg Coughlin Runs 6.788/207.56, Now #10
Almost two clean and straight passes this time, with Coughlin moving around just a little down low.
Krisher has the launch down right and moves into the new #1 spot on a great looking pass.
Ron Krisher's incremental times: 60ft-0.989 sec., 330ft-2.759, 660ft-4.232/167.45 mph, 1,000ft-5.500.
Jeg Coughlin's incremental times: 60ft-0.996 sec., 330ft-2.890, 660ft-4.407/163.77 mph, 1,000ft-5.701.
Left Lane: Shane Gray Runs 6.563/209.88, Now #1
Right Lane: Allen Johnson Runs 12.417/70.91, Now #13
Rodger Brogdon is on the bump spot at 13.970.
Another broken pass in the right lane and it's Johnson's Avenger this time.
Gray misses a career best by 0.002 and shoot up into the number one position.
Shane Gray's incremental times: 60ft-0.975 sec., 330ft-2.745, 660ft-4.219/167.24 mph, 1,000ft-5.490.
Allen Johnson's incremental times: 60ft-1.002 sec., 330ft-3.351, 660ft-6.270/076.09 mph, 1,000ft-9.383.
Left Lane: Jason Line Runs 6.561/211.16, Now #1
Right Lane: Greg Stanfield Runs 6.610/210.05, Now #7
Larry Morgan is on the bump spot at 6.834.
Line uses a lot of track down low and Stanfield makes the right lane look easy.
Line takes the new top spot and Stanfield goes into the top half of the field.
Jason Line's incremental times: 60ft-0.987 sec., 330ft-2.759, 660ft-4.227/167.76 mph, 1,000ft-5.494.
Greg Stanfield's incremental times: 60ft-1.005 sec., 330ft-2.787, 660ft-4.265/166.95 mph, 1,000ft-5.537.
Left Lane: Mike Edwards Runs 6.576/210.67, Now #7
Right Lane: Greg Anderson Runs 6.563/211.20, Now #2
Warren Johnson is on the bump spot at 6.694.
Last pair of the session and the two top spots in the 2010 Championship chase.
Both cars make it look easy and Anderson improves his points lead with a strong pass that matches Shane Gray's ET, but with a better MPH, into the final number two spot of the session.
Edwards is stronger down low, but can't match the Summit car's pace down the track.
Mike Edwards' incremental times: 60ft-0.980 sec., 330ft-2.762, 660ft-4.237/167.30 mph, 1,000ft-5.506.
Greg Anderson's incremental times: 60ft-0.992 sec., 330ft-2.761, 660ft-4.230/167.63 mph, 1,000ft-5.496.
2:23 p.m. Jason Line is Johnny Gray is on the bump spot at 6.638.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old Nov 12, 2010 | 02:51 PM
Round 2 Qualifying
Fri, 12 Nov 2010, 05:36 PM
Pro Stock Qualifying, Session #2 Order
POMONA, Calif. - Order after 2 rounds of qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 46th annual Automobile Club of Southern California NHRA Finals:
Psn---Num-Driver, Home Town, Car Type---------------Qual-ET--Qual-Spd-Top Spd
1 55 V. Gaines, Lakewood CO, '10 Avenger 6.551 210.83 210.83
2 7 Allen Johnson, Greeneville TN, '10 Avenger 6.553 211.39 211.39
3 3 Jason Line, Mooresville NC, '09 GXP 6.561 211.16 211.16
4 2 Greg Anderson, Morresville NC, '09 GXP 6.563 211.20 211.20
5 730 Shane Gray, Denver NM, '10 GXP 6.563 209.88 209.88
6 7406 Vinnie Deceglie, Rancho Cucamonga CA, '10 Aven 6.564 210.47 210.67
7 4 Greg Stanfield, Bossier City LA, '09 GXP 6.567 210.05 210.05
8 6 Ron Krisher, Warren OH, '10 GXP 6.569 210.60 210.60
9 2062 Ronnie Humphrey, Jacksonville NC, '09 GXP 6.570 211.26 211.26
10 1 Mike Edwards, Coweta OK, '09 GXP 6.574 210.24 210.67
11 41 Rodger Brogdon, Tomball TX, '09 GXP 6.582 209.95 209.95
12 50 Jeg Coughlin, Delaware OH, '10 Cobalt 6.593 209.69 209.69
------------ Not Qualified ------------
13 51 Dave Connolly, Elyria OH, '10 Cobalt 6.597 209.69 209.69
14 406 Bob Yonke, Burleson TX, '10 GXP 6.607 209.75 209.75
15 8 Kurt Johnson, Sugar Hill GA, '08 GXP 6.609 209.39 209.82
16 9 Johnny Gray, Artesia NM, '09 GXP 6.615 208.75 208.97
17 208 Warren Johnson, Sugar Hill GA, '09 GXP 6.629 209.65 209.65
18 357 Larry Morgan, Newark OH, '10 Mustang 6.634 208.78 208.78
19 381 Jerry Haas, Fenton MO, '10 Mustang 6.651 207.18 207.18
20 430 Erica Enders, New Orleans LA, '10 Mustang 6.671 206.54 206.54
21 752 Gordie Rivera, Yuma AZ, '09 GXP 6.827 203.34 203.34
Old Nov 13, 2010 | 02:38 PM
Round 3 Qualifying
Sat, 13 Nov 2010, 03:22 PM
Pro Stock Qualifying Notes, Session #3
By David Gerard
POMONA, Calif. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 46th annual Automobile Club of Southern California NHRA Finals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Right Lane: Jerry Haas Runs 6.675/207.11, Now #13; No Prior Run
11:20 a.m. Weather conditions: air temperature 73 degrees, relative humidity 21 percent, barometer 29.02 inches, adjusted altitude 2,311 feet, track temperature 92 degrees.
Haas is subbing for Glidden. We will now starting qualifying against a sixteen car field. No bump yet.
Haas doesn't improve on yesterday's time. This ET may not keep him in the field.
Jerry Haas' incremental times: 60ft-1.000 sec., 330ft-2.799, 660ft-4.295/164.11 mph, 1,000ft-5.586.
Left Lane: Shane Gray Runs 11.903/74.11, Now #5; Best prior run: 6.563/209.88, Was #5
Right Lane: Larry Morgan Runs 6.980/203.92, Now #14; No Prior Run
Both cars shake and move towards the centerline. Gray's is the worst of the two and he has to lift. Morgan must have pumped the throttle, as he runs a lot slower than earlier.
Left Lane: Gordie Rivera Runs 22.958/33.61, Now #16; No Prior Run
Right Lane: Warren Johnson Runs 6.610/210.14, Now #13; No Prior Run
Rivera fires and falls back off the line.
Johnson spins hard off the line and still picks up some ET to set a bump spot.
Warren Johnson's incremental times: 60ft-1.004 sec., 330ft-2.782, 660ft-4.262/166.56 mph, 1,000ft-5.537.
Left Lane: Erica Enders Runs 6.666/207.05, Now #15; No Prior Run
Right Lane: Johnny Gray Runs 6.616/208.84, Now #14; No Prior Run
Gordie Rivera is on the bump spot at 22.958.
Gray had the sixteenth best ET coming into the session.
Both cars get into the sub-one second sixty foot time and Gray runs 0.001 to his prior best.
Erica Enders' incremental times: 60ft-0.998 sec., 330ft-2.795, 660ft-4.288/164.91 mph, 1,000ft-5.577.
Johnny Gray's incremental times: 60ft-0.991 sec., 330ft-2.773, 660ft-4.257/165.92 mph, 1,000ft-5.537.
Left Lane: Jason Line Runs 6.553/210.90, Now #3; Best prior run: 6.561/211.16, Was #3
Right Lane: Dave Connolly Runs 6.573/210.87, Now #10; No Prior Run
Line is looking to move up the ladder to the top spot.
Two strong passes with Connolly moving up to the #10 spot. Line runs better than earlier, but stays #3 for now.
Jason Line's incremental times: 60ft-0.984 sec., 330ft-2.747, 660ft-4.215/167.63 mph, 1,000ft-5.484.
Dave Connolly's incremental times: 60ft-0.989 sec., 330ft-2.760, 660ft-4.234/167.14 mph, 1,000ft-5.504.
Left Lane: Bob Yonke Runs 6.608/209.39, Now #14; No Prior Run
Right Lane: Greg Anderson Runs 6.588/210.77, Now #4; Best prior run: 6.563/211.20, Was #4
Erica Enders is on the bump spot at 6.666.
Anderson's car move around off the starting line and it costs him.
Yonke runs within a thousands of his best and takes the number fourteenth spot.
Bob Yonke's incremental times: 60ft-0.993 sec., 330ft-2.770, 660ft-4.252/166.03 mph, 1,000ft-5.530.
Greg Anderson's incremental times: 60ft-0.989 sec., 330ft-2.772, 660ft-4.247/166.72 mph, 1,000ft-5.518.
Left Lane: Ron Krisher Runs 6.582/211.43, Now #8; Best prior run: 6.569/210.60, Was #8
Right Lane: Jeg Coughlin Runs 6.582/210.54, Now #12; Best prior run: 6.593/209.69, Was #13
Johnny Gray is on the bump spot at 6.616.
Krisher spins a little off the line and won't improve.
Coughlin matches his ET and that moves him into the field in the #12 spot.
Ron Krisher's incremental times: 60ft-1.014 sec., 330ft-2.779, 660ft-4.249/167.74 mph, 1,000ft-5.515.
Jeg Coughlin's incremental times: 60ft-0.997 sec., 330ft-2.767, 660ft-4.241/167.16 mph, 1,000ft-5.512.
Left Lane: Kurt Johnson Runs 6.596/209.95, Now #14; No Prior Run
Right Lane: Greg Stanfield Runs 9.769/89.83, Now #7; Best prior run: 6.567/210.05, Was #7
Standfields car moves hard towards the center line and he has to lift.
Johnson makes a nice clean looking pass and bumps Gray out to secure the #14 spot for now.
Kurt Johnson's incremental times: 60ft-0.987 sec., 330ft-2.766, 660ft-4.246/166.50 mph, 1,000ft-5.521.
Greg Stanfield's incremental times: 60ft-0.976 sec., 330ft-2.885, 660ft-5.085/100.98 mph, 1,000ft-7.429.
Left Lane: Ronnie Humphrey Runs 6.580/210.44, Now #9; Best prior run: 6.570/211.26, Was #9
Right Lane: Vinnie Deceglie Runs 6.575/210.54, Now #6; Best prior run: 6.564/210.47, Was #6
Warren Johnson is on the bump spot at 6.610, but it looks like everyone below him have already run in this session.
Two strong passes for the conditions, but both cars will stay in their current spots on the ladder.
Ronnie Humphrey's incremental times: 60ft-0.988 sec., 330ft-2.764, 660ft-4.237/167.12 mph, 1,000ft-5.508.
Vinnie Deceglie's incremental times: 60ft-0.980 sec., 330ft-2.754, 660ft-4.232/166.64 mph, 1,000ft-5.504.
Left Lane: Rodger Brogdon Runs 6.572/210.50, Now #10; Best prior run: 6.582/209.95, Was #13
Right Lane: Allen Johnson Runs 15.904/53.84, Now #2; Best prior run: 6.553/211.39, Was #2
Johnson's car spins off the line and he clicks it off line.
Brogdon takes advantage of the better left lane and powers up to the new number ten position.
Rodger Brogdon's incremental times: 60ft-0.991 sec., 330ft-2.757, 660ft-4.230/167.18 mph, 1,000ft-5.500.
Allen Johnson's incremental times: 60ft-1.005 sec., 330ft-3.998, 660ft-7.802/058.03 mph, 1,000ft-11.902.
Left Lane: Mike Edwards Runs 6.574/209.88, Now #12; Best prior run: 6.574/210.24, Was #12
Right Lane: V. Gaines Runs 6.585/210.87, Now #1; Best prior run: 6.551/210.83, Was #1
Strong leave for Edwards and he matches his prior best performance, with just a little slower MPH, to stay #12.
Our number one qualifier, Gaines is a little slow off the line and doesn't improve.
Mike Edwards' incremental times: 60ft-0.979 sec., 330ft-2.751, 660ft-4.227/166.93 mph, 1,000ft-5.500.
V. Gaines' incremental times: 60ft-1.006 sec., 330ft-2.774, 660ft-4.248/167.34 mph, 1,000ft-5.517.
11:47 a.m. Warren Johnson is on the bump spot at 6.610.
Old Nov 15, 2010 | 12:18 PM
Summary of Eliminations
Summary of Eliminations in Pro Stock
POMONA, Calif. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 46th annual Automobile Club of Southern California NHRA Finals:
Round 1:
Greg Stanfield, Bossier City LA, '09 GXP, Left lane, (0.041) 6.585 209.85 def. Ron Krisher, Warren OH, '10 GXP, (0.053) 6.625 210.28
Ronnie Humphrey, Jacksonville NC, '09 GXP, Right lane, (0.201) 6.631 210.24 def. Vinnie Deceglie, Rancho Cucamonga CA, '10 Avenger,(-0.065 foul) 6.610 209.88
Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.040) 6.587 210.24 def. Mike Edwards, Coweta OK, '09 GXP, (0.012) 14.885 47.14
V. Gaines, Lakewood CO, '10 Avenger, Left lane, (0.043) 6.575 210.31 def. Warren Johnson, Sugar Hill GA, '09 GXP, (0.068) 6.717206.80
Jeg Coughlin, Delaware OH, '10 Cobalt, Right lane, (0.012) 6.587 210.01 def. Greg Anderson, Morresville NC, '09 GXP, (0.021) 6.579211.10
Allen Johnson, Greeneville TN, '10 Avenger, Left lane, (0.022) 10.107 90.81 def. Bob Yonke, Burleson TX, '10 GXP, (-0.091 foul)6.621 209.04
Kurt Johnson, Sugar Hill GA, '08 GXP, Right lane, (0.042) 6.631 209.23 def. Jason Line, Mooresville NC, '09 GXP, (0.026) 6.675210.11
Shane Gray, Denver NC, '10 GXP, Left lane, (0.034) 6.593 208.94 def. Dave Connolly, Elyria OH, '10 Cobalt, (0.070) 6.585 210.18
Round 2:
S Gray, Left lane, (0.044) 6.608 208.84 def. K Johnson, (0.046) 6.622 208.94
V Gaines, Left lane, (0.042) 6.558 210.41 def. R Humphrey, (0.095) 6.633 209.72
A Johnson, Right lane, (0.003) 6.592 210.08 def. G Stanfield, (0.027) 6.589 209.75
Round 3:
J Coughlin, Left lane, (0.023) 6.622 209.88 def. A Johnson, (-0.010 foul) 6.632 210.31
S Gray, Right lane, (0.025) 6.603 209.10 def. V Gaines, (0.060) 6.582 210.28
Round 4:S Gray, Left lane, (0.010) 6.566 209.20 def. J Coughlin, (0.046) 6.568 210.18
Low ET: V. Gaines 6.551 seconds
Top Speed: Ron Krisher 211.43 MPH
Old Nov 15, 2010 | 12:19 PM
That's All Folks
End of the season... Next race will be here in Pomona in February... till then......
MReeves
Funny Car
Nov 15, 2010 12:36 PM
MReeves
Stock Eliminator
Nov 15, 2010 12:11 PM
MReeves
Super Stock
Nov 15, 2010 12:05 PM
MReeves
Super Gas
Nov 12, 2010 02:21 PM
MReeves
Nov 5, 2009 07:04 PM
