NHRA Route 66 Nationals Joliet
Old Jul 8, 2011 | 03:05 PM
Fri, 8 Jul 2011, 05:48 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
JOLIET, Ill. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Kevin Lawrence Runs 7.088/151.80, Now #2
Right Lane: Steve Schmidt Runs 6.777/203.86, Now #1
Weather conditions: air temperature 92 degrees, relative humidity 30 percent, barometer 29.18 inches, adjusted altitude 3,566 feet, track temperature 128 degrees.
Lawrence makes his first appearance on the NHRA tour this year. He has the chutes out early. Schmidt with a little wiggle early in the run.
Left Lane: Mark Hogan Runs 7.094/202.27, Now #3
Right Lane: Dave River Runs 13.717/61.16, Now #4
River shook right off the starting line and clicked it off. Hogan with a clean pass.
Left Lane: Steve Spiess Runs 6.687/205.72, Now #1
Right Lane: Frank Gugliotta Runs 15.449/46.87, Now #6
Gugliotta was really loose right at the hit and clicked it off. Spiess with a full pass to go to then number one spot. Steve Spiess' incremental times: 60ft-0.993 sec., 330ft-2.796, 660ft-4.298/164.37 mph, 1,000ft-5.593.
Left Lane: Robert Patrick Runs 6.779/204.45, Now #4
Right Lane: Buddy Perkinson Runs 6.741/206.29, Now #2
Robert Patrick's incremental times: 60ft-1.018 sec., 330ft-2.849, 660ft-4.367/162.47 mph, 1,000ft-5.676.
Buddy Perkinson's incremental times: 60ft-1.024 sec., 330ft-2.849, 660ft-4.352/164.13 mph, 1,000ft-5.648.
Left Lane: Richard Freeman Runs 12.104/71.25, Now #8
Right Lane: Kurt Johnson Runs 6.697/207.05, Now #2
Freeman is real loose right off the starting line and pushes the clutch in. Johnson with a nice pass...top speed so far...Kurt Johnson's incremental times: 60ft-1.005 sec., 330ft-2.810, 660ft-4.314/163.95 mph, 1,000ft-5.607.
Left Lane: Warren Johnson Runs 9.638/95.19, Now #8
Right Lane: V. Gaines No Time, Now #12
Gaines with a new car here and has problems on the burnout and is pushed of the starting line. Johnson makes a quick move toward the wall and he clicks it off.
Left Lane: Larry Morgan Runs 6.646/207.94, Now #1
Right Lane: Ronnie Humphrey Runs 6.708/205.82, Now #4
Humphrey with a nice pass...Ronnie Humphrey's incremental times: 60ft-1.003 sec., 330ft-2.813, 660ft-4.316/163.97 mph, 1,000ft-5.612. Morgan with a great pass to start the weekend...Larry Morgan's incremental times: 60ft-0.989 sec., 330ft-2.783, 660ft-4.275/164.91 mph, 1,000ft-5.561.
Left Lane: Ron Krisher Runs 6.663/208.26, Now #2
Right Lane: Shane Gray Runs 6.669/208.55, Now #3
A couple good looking passes here for the number two and three spots with Gray running the fastest pass of the session. Ron Krisher's incremental times: 60ft-1.003 sec., 330ft-2.804, 660ft-4.297/165.09 mph, 1,000ft-5.582.
Shane Gray's incremental times: 60ft-1.005 sec., 330ft-2.809, 660ft-4.303/165.38 mph, 1,000ft-5.587.
Left Lane: Erica Enders Runs 6.616/208.30, Now #1
Right Lane: Allen Johnson Runs 15.844/51.96, Now #17
Johnson with violent tire shake as soon as he lets the clutch out and clicks it off. enders with a great pass and she goes to the number one spot...Erica Enders' incremental times: 60ft-0.981 sec., 330ft-2.766, 660ft-4.253/165.60 mph, 1,000ft-5.535.
Left Lane: Rodger Brogdon Runs 6.669/207.40, Now #6
Right Lane: Greg Anderson Runs 6.634/209.14, Now #2
Brogdon with a real nice pass to get into the top half of the show. Rodger Brogdon's incremental times: 60ft-1.002 sec., 330ft-2.802, 660ft-4.296/164.85 mph, 1,000ft-5.584. Anderson with great pass to go to the number two spot and has the fastest pass of the session. Greg Anderson's incremental times: 60ft-1.003 sec., 330ft-2.791, 660ft-4.276/166.13 mph, 1,000ft-5.555.
Left Lane: Greg Stanfield Runs 6.657/206.83, Now #4
Right Lane: Vincent Nobile Runs 6.660/208.20, Now #5
Theses two were side-by-side all the way down the 1320. Stanfield goes to the number four spot. Greg Stanfield's incremental times: 60ft-0.992 sec., 330ft-2.785, 660ft-4.280/164.83 mph, 1,000ft-5.569. Nobile to the number five spot...Vincent Nobile's incremental times: 60ft-1.000 sec., 330ft-2.792, 660ft-4.287/165.19 mph, 1,000ft-5.575.
Left Lane: Mike Edwards Runs 6.642/208.04, Now #4
Right Lane: Jason Line Runs 6.632/207.66, Now #2
A couple good passes to wrap up round one of qualifying...Line goes to the number two spot. Jason Line's incremental times: 60ft-0.988 sec., 330ft-2.778, 660ft-4.266/165.56 mph, 1,000ft-5.548. Edwards with good pass for the number four spot. Mike Edwards' incremental times: 60ft-0.991 sec., 330ft-2.786, 660ft-4.276/165.54 mph, 1,000ft-5.560.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old Jul 8, 2011 | 06:16 PM
Round 2 Qualifying
Fri, 8 Jul 2011, 08:52 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
JOLIET, Ill. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: V. Gaines Runs 6.667/207.40, Now #9; No Prior Run
Right Lane: Mark Hogan Runs 7.646/153.63, Now #19; No Prior Run
Weather conditions: air temperature 88 degrees, relative humidity 35 percent, barometer 29.18 inches, adjusted altitude 3,345 feet, track temperature 114 degrees.
Hogan was real loose right at the hit. Gaines with a great looking pass to get in the show. V. Gaines' incremental times: 60ft-1.003 sec., 330ft-2.802, 660ft-4.294/165.21 mph, 1,000ft-5.582.
Left Lane: Allen Johnson Runs 6.622/208.81, Now #2; Best prior run: 15.844/51.96, Was #24
Right Lane: Richard Freeman Runs 6.683/207.50, Now #13; Best prior run: 12.104/71.25, Was #21
Johnson launched with a great looking pass to go to the number two spot. Allen Johnson's incremental times: 60ft-0.994 sec., 330ft-2.782, 660ft-4.265/166.19 mph, 1,000ft-5.543. Freeman with a good pass, but not quick enough to get in the show.
Left Lane: Frank Gugliotta Runs 9.195/90.16, Now #23; Best prior run: 15.449/46.87, Was #24
Right Lane: Warren Johnson Runs 6.641/208.20, Now #5; Best prior run: 9.638/95.19, Was #22
Johnson with a good pass to get into the top half of the show...Warren Johnson's incremental times: 60ft-0.995 sec., 330ft-2.781, 660ft-4.272/165.13 mph, 1,000ft-5.558. Gugliotta pushes in the clutch early.
Left Lane: Dave River Runs 6.893/198.29, Now #21; Best prior run: 13.717/61.16, Was #24
Right Lane: Kevin Lawrence No Time, Now #22; Best prior run: 7.088/151.80, Was #21
Lawrence's car won't start and he will miss this session. River gets down the track, but won't get in the show.
Left Lane: Steve Schmidt Runs 6.747/203.49, Now #20; Best prior run: 6.777/203.86, Was #19
Right Lane: Robert Patrick Runs 6.704/205.26, Now #17; Best prior run: 6.779/204.45, Was #20
Patrick with a nice pass, but will not get in the show. Schmidt improves, but not enough to get in the show.
Left Lane: Buddy Perkinson Runs 6.689/206.70, Now #16; Best prior run: 6.741/206.29, Was #19
Right Lane: Steve Spiess Runs 6.661/206.51, Now #10; Best prior run: 6.687/205.72, Was #15
Perkinson improves, but not enough to get in the show. Spiess with a real good pass to get in the show and that will bump out Gray. Steve Spiess' incremental times: 60ft-0.984 sec., 330ft-2.779, 660ft-4.277/164.61 mph, 1,000ft-5.575.
Left Lane: Ronnie Humphrey Runs 6.638/206.51, Now #6; Best prior run: 6.708/205.82, Was #19
Right Lane: Rodger Brogdon Runs 6.619/208.17, Now #2; Best prior run: 6.669/207.40, Was #14
humphrey with a real nice pass to get into the top half of the show. Ronnie Humphrey's incremental times: 60ft-0.977 sec., 330ft-2.770, 660ft-4.261/164.89 mph, 1,000ft-5.549. Brogdon launched hard and was straight down the groove to go to the number two spot. Rodger Brogdon's incremental times: 60ft-0.983 sec., 330ft-2.768, 660ft-4.255/165.78 mph, 1,000ft-5.537.
Left Lane: Kurt Johnson Runs 6.631/208.20, Now #5; Best prior run: 6.697/207.05, Was #18
Right Lane: Ron Krisher Runs 6.612/208.52, Now #1; Best prior run: 6.663/208.26, Was #13
Johnson with a real nice pass to get into the top half of the show. Kurt Johnson's incremental times: 60ft-0.986 sec., 330ft-2.772, 660ft-4.262/165.21 mph, 1,000ft-5.548. Krisher with a great pass to go to the number one spot. Ron Krisher's incremental times: 60ft-0.984 sec., 330ft-2.765, 660ft-4.250/165.94 mph, 1,000ft-5.531.
Left Lane: Shane Gray Runs 6.606/209.04, Now #1; Best prior run: 6.669/208.55, Was #16
Right Lane: Greg Stanfield Runs 6.616/208.04, Now #4; Best prior run: 6.657/206.83, Was #12
Stanfield with a really nice pass to get into the top half of the show. Greg Stanfield's incremental times: 60ft-0.976 sec., 330ft-2.759, 660ft-4.247/165.56 mph, 1,000ft-5.531. Gray just got bumped out and launched hard and goes straight down the groove to go to the number one spot. Shane Gray's incremental times: 60ft-0.985 sec., 330ft-2.769, 660ft-4.251/166.27 mph, 1,000ft-5.529.
Left Lane: Vincent Nobile Runs 6.626/208.30, Now #7; Best prior run: 6.660/208.20, Was #14
Right Lane: Larry Morgan Runs 6.645/208.26, Now #14; Best prior run: 6.646/207.94, Was #13
Morgan made a quick move toward the centerline and reeled it in, but will not get in the show. Nobile gets in the show...Vincent Nobile's incremental times: 60ft-0.987 sec., 330ft-2.772, 660ft-4.260/165.56 mph, 1,000ft-5.544.
Left Lane: Greg Anderson Runs 6.586/208.97, Now #1; Best prior run: 6.634/209.14, Was #10
Right Lane: Mike Edwards Runs 6.614/209.04, Now #4; Best prior run: 6.642/208.04, Was #13
This was a great drag race as Edwards gets back into the show into the top half of the field. Mike Edwards' incremental times: 60ft-0.985 sec., 330ft-2.771, 660ft-4.257/166.01 mph, 1,000ft-5.536. Anderson launched hard and was straight down the groove into the number one spot. Greg Anderson's incremental times: 60ft-0.978 sec., 330ft-2.756, 660ft-4.233/166.81 mph, 1,000ft-5.509.
Left Lane: Jason Line Runs 6.597/207.66, Now #2; Best prior run: 6.632/207.66, Was #11
Right Lane: Erica Enders Runs 6.603/208.78, Now #3; Best prior run: 6.616/208.30, Was #5
This was a great side-by-side drag race with Line going to the number two spot and Enders goes to the number three spot. Jason Line's incremental times: 60ft-0.976 sec., 330ft-2.753, 660ft-4.235/166.09 mph, 1,000ft-5.514.
Erica Enders' incremental times: 60ft-0.979 sec., 330ft-2.759, 660ft-4.243/166.07 mph, 1,000ft-5.523.
Old Jul 10, 2011 | 04:48 AM
Round 3 Qualifying
Sat, 9 Jul 2011, 06:24 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
JOLIET, Ill. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Frank Gugliotta Runs 6.847/187.44, Now #13; No Prior Run
Right Lane: Kevin Lawrence No Time, Now #24; No Prior Run
Weather conditions: air temperature 92 degrees, relative humidity 40 percent, barometer 29.22 inches, adjusted altitude 3,764 feet, track temperature 134 degrees.
Gugliotta with his quickest pass of the weekend...The timing block blew over before Lawrence got there so he won't get a time...
Left Lane: Dave River Runs 6.887/199.61, Now #15; No Prior Run
Right Lane: Mark Hogan Runs 6.855/179.90, Now #14; No Prior Run
Hogan with a lot of tire shake right at the hit...
Left Lane: Steve Schmidt Runs 6.796/203.06, Now #14; No Prior Run
Right Lane: Robert Patrick Runs 6.748/205.10, Now #13; No Prior Run
Left Lane: Buddy Perkinson Runs 6.743/206.26, Now #13; No Prior Run
Right Lane: Richard Freeman Runs 14.814/55.91, Now #19; No Prior Run
Freeman with problems early and pushed in the clutch. Perkinson with a good pass here in the heat of the day.
Left Lane: V. Gaines Runs 6.763/207.11, Now #16; No Prior Run
Right Lane: Steve Spiess Runs 6.709/205.26, Now #13; No Prior Run
Spiess with a real nice pass to get into the show...Steve Spiess' incremental times: 60ft-0.999 sec., 330ft-2.804, 660ft-4.310/163.67 mph, 1,000ft-5.617. Gaines with the new car and he gets in on the bump.
Left Lane: Ronnie Humphrey Runs 6.672/205.72, Now #12; Best prior run: 6.638/206.51, Was #12
Right Lane: Larry Morgan Runs 6.703/206.45, Now #13; No Prior Run
Morgan gets into the show and he is now the quickest Ford...no help here for Humphrey.
Left Lane: Kurt Johnson Runs 6.678/206.42, Now #11; Best prior run: 6.631/208.20, Was #11
Right Lane: Warren Johnson Runs 6.675/207.18, Now #13; No Prior Run
WJ gets into the show...Warren Johnson's incremental times: 60ft-1.001 sec., 330ft-2.799, 660ft-4.297/164.67 mph, 1,000ft-5.587.
Left Lane: Vincent Nobile Runs 6.685/206.61, Now #10; Best prior run: 6.626/208.30, Was #10
Right Lane: Rodger Brogdon Runs 6.684/207.34, Now #8; Best prior run: 6.619/208.17, Was #8
Vincent Nobile's incremental times: 60ft-0.997 sec., 330ft-2.801, 660ft-4.301/164.21 mph, 1,000ft-5.595.
Rodger Brogdon's incremental times: 60ft-1.009 sec., 330ft-2.810, 660ft-4.307/164.69 mph, 1,000ft-5.597.
Left Lane: Allen Johnson Runs 6.650/208.01, Now #9; Best prior run: 6.622/208.81, Was #9
Right Lane: Greg Stanfield Runs 6.701/205.29, Now #7; Best prior run: 6.616/208.04, Was #7
Johnson with the quickest pass of the session...Allen Johnson's incremental times: 60ft-0.993 sec., 330ft-2.787, 660ft-4.280/165.03 mph, 1,000ft-5.565.
Left Lane: Shane Gray Runs 6.658/207.34, Now #4; Best prior run: 6.606/209.04, Was #4
Right Lane: Mike Edwards Runs 6.651/207.72, Now #6; Best prior run: 6.614/209.04, Was #6
Edwards with the second quickest pass of the session...Mike Edwards' incremental times: 60ft-0.994 sec., 330ft-2.785, 660ft-4.278/165.13 mph, 1,000ft-5.565.
Left Lane: Jason Line Runs 6.622/207.53, Now #2; Best prior run: 6.597/207.66, Was #2
Right Lane: Ron Krisher Runs 6.653/207.88, Now #5; Best prior run: 6.612/208.52, Was #5
Line with a great pass, the quickest pass of the round. Jason Line's incremental times: 60ft-0.978 sec., 330ft-2.762, 660ft-4.251/165.13 mph, 1,000ft-5.537.
Left Lane: Greg Anderson Runs 6.628/208.55, Now #1; Best prior run: 6.586/208.97, Was #1
Right Lane: Erica Enders Runs 6.650/207.30, Now #3; Best prior run: 6.603/208.78, Was #3
Anderson with the second quickest pass of the session...Greg Anderson's incremental times: 60ft-0.991 sec., 330ft-2.780, 660ft-4.266/165.90 mph, 1,000ft-5.547.
Old Jul 10, 2011 | 04:52 AM
Final Qualifying
Sat, 9 Jul 2011, 08:58 PM
Pro Stock Qualifying Notes, Final Session
By Rick Green
JOLIET, Ill. - Notes from final, round 4 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Kevin Lawrence Runs 6.796/200.71, Now #20; No Prior Run
Right Lane: Dave River Runs 6.898/200.05, Now #23; Best prior run: 6.887/199.61, Was #22
Weather conditions: air temperature 91 degrees, relative humidity 43 percent, barometer 29.20 inches, adjusted altitude 3,740 feet, track temperature 117 degrees.
Kevin Lawrence's incremental times: 60ft-0.990 sec., 330ft-2.824, 660ft-4.356/160.63 mph, 1,000ft-5.679.
Dave River's incremental times: 60ft-1.006 sec., 330ft-2.879, 660ft-4.435/158.78 mph, 1,000ft-5.772.
Left Lane: Richard Freeman Runs 6.661/207.08, Now #13; Best prior run: 14.814/55.91, Was #24
Right Lane: Frank Gugliotta Runs 6.679/206.10, Now #15; Best prior run: 6.847/187.44, Was #21
This was a great pass by both of these guys...Gugliotta with his quickest pass of the weekend to get in the show. Frank Gugliotta's incremental times: 60ft-0.995 sec., 330ft-2.791, 660ft-4.289/164.35 mph, 1,000ft-5.585. Freeman with his quickest pass of the weekend and he gets in the show. Richard Freeman's incremental times: 60ft-0.986 sec., 330ft-2.785, 660ft-4.282/164.57 mph, 1,000ft-5.573.
Left Lane: Mark Hogan Runs 6.771/199.49, Now #21; Best prior run: 6.855/179.90, Was #23
Right Lane: Steve Schmidt No Time, Now #22; Best prior run: 6.796/203.06, Was #21
Schmidt with problems early and he pushed in the clutch and came to a stop on the track. Hogan with his quickest pass of the weekend, but will not get in the show.
Left Lane: Robert Patrick Runs 6.723/205.01, Now #19; Best prior run: 6.748/205.10, Was #19
Right Lane: V. Gaines Runs 6.683/207.30, Now #16; Best prior run: 6.763/207.11, Was #20
No help here for Patrick and he will not get in the show. Gaines will stay on the bump...
Left Lane: Steve Spiess Runs 6.665/205.32, Now #14; Best prior run: 6.709/205.26, Was #18
Right Lane: Buddy Perkinson Runs 6.683/206.32, Now #18; Best prior run: 6.743/206.26, Was #20
Spiess gets in the show...Steve Spiess' incremental times: 60ft-0.973 sec., 330ft-2.767, 660ft-4.270/163.81 mph, 1,000ft-5.568. That will bump out Gaines. Perkinson with his quickest pass of the weekend and he will not get in the show.
Left Lane: Larry Morgan Runs 6.649/207.27, Now #13; Best prior run: 6.703/206.45, Was #19
Right Lane: Ronnie Humphrey Runs 6.690/205.85, Now #12; Best prior run: 6.638/206.51, Was #12
Morgan gets back in the show...Larry Morgan's incremental times: 60ft-0.984 sec., 330ft-2.778, 660ft-4.274/164.43 mph, 1,000ft-5.563. No help here for Humphrey...Ronnie Humphrey's incremental times: 60ft-0.998 sec., 330ft-2.803, 660ft-4.302/164.11 mph, 1,000ft-5.597.
Left Lane: Warren Johnson Runs 6.651/207.08, Now #14; Best prior run: 6.675/207.18, Was #16
Right Lane: Kurt Johnson Runs 6.662/207.40, Now #11; Best prior run: 6.631/208.20, Was #11
WJ gets off the bump spot, moving up the ladder a couple spots. Warren Johnson's incremental times: 60ft-0.989 sec., 330ft-2.779, 660ft-4.276/164.71 mph, 1,000ft-5.565. No help here for Kurt...Kurt Johnson's incremental times: 60ft-0.995 sec., 330ft-2.788, 660ft-4.285/164.65 mph, 1,000ft-5.575.
Left Lane: Rodger Brogdon Runs 6.628/207.59, Now #8; Best prior run: 6.619/208.17, Was #8
Right Lane: Vincent Nobile Runs 6.643/207.18, Now #10; Best prior run: 6.626/208.30, Was #10
Brogdon with the quickest pass of the session...Rodger Brogdon's incremental times: 60ft-0.984 sec., 330ft-2.769, 660ft-4.258/165.25 mph, 1,000ft-5.543. Nobile with the second quickest pass of the session...Vincent Nobile's incremental times: 60ft-0.981 sec., 330ft-2.770, 660ft-4.265/164.55 mph, 1,000ft-5.555.
Left Lane: Greg Stanfield Runs 6.663/206.16, Now #7; Best prior run: 6.616/208.04, Was #7
Right Lane: Allen Johnson No Time, Now #9; Best prior run: 6.622/208.81, Was #9
Johnson with problems early in the run and pushed in the clutch and was timed out before he could coast through the 1320...Stanfield with a clean pass. Greg Stanfield's incremental times: 60ft-0.987 sec., 330ft-2.778, 660ft-4.277/164.47 mph, 1,000ft-5.570.
Left Lane: Mike Edwards Runs 6.617/208.04, Now #6; Best prior run: 6.614/209.04, Was #6
Right Lane: Shane Gray Runs 6.631/207.88, Now #4; Best prior run: 6.606/209.04, Was #4
This was a great drag race with Edwards running the quickest pass of the round and Gray runs the third quickest pass of the round. Mike Edwards' incremental times: 60ft-0.979 sec., 330ft-2.762, 660ft-4.251/165.48 mph, 1,000ft-5.535.
Shane Gray's incremental times: 60ft-0.984 sec., 330ft-2.771, 660ft-4.263/165.23 mph, 1,000ft-5.548.
Left Lane: Ron Krisher Runs 6.625/208.01, Now #5; Best prior run: 6.612/208.52, Was #5
Right Lane: Jason Line Runs 6.644/206.39, Now #2; Best prior run: 6.597/207.66, Was #2
Krisher with a great pass, the second quickest pass of the round. Ron Krisher's incremental times: 60ft-0.971 sec., 330ft-2.766, 660ft-4.259/165.13 mph, 1,000ft-5.543. Line with the sixth quickest pass of the round. Jason Line's incremental times: 60ft-0.978 sec., 330ft-2.769, 660ft-4.263/164.67 mph, 1,000ft-5.554.
Left Lane: Erica Enders Runs 6.631/207.66, Now #3; Best prior run: 6.603/208.78, Was #3
Right Lane: Greg Anderson Runs 6.617/208.20, Now #1; Best prior run: 6.586/208.97, Was #1
Anderson ties Edwards for the quickest pass of the round, and gets the three bonus points based on his faster speed. Greg Anderson's incremental times: 60ft-0.983 sec., 330ft-2.767, 660ft-4.253/165.92 mph, 1,000ft-5.535. Enders with the sixth quickest pass of the session...Erica Enders' incremental times: 60ft-0.977 sec., 330ft-2.769, 660ft-4.260/165.15 mph, 1,000ft-5.547.
Anderson holds on to the number one spot and this is first number one qualifying spot since Sonoma 2009. Line finished second and the is the 25th time the teammates have qualified number one and two.
Old Jul 11, 2011 | 05:14 AM
Summary of Eliminations
Sun, 10 Jul 2011, 06:38 PM
Summary of Eliminations in Pro Stock
JOLIET, Ill. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 14th annual O'Reilly Auto Parts Route 66 NHRA Nationals:
Round 1:
Rodger Brogdon, Tomball TX, '09 GXP, Left lane, (0.065) 6.674 207.24 def. Allen Johnson,Greeneville TN, '11 Avenger, (0.051) 7.878 125.24
Vincent Nobile, Dix Hills NY, '10 Avenger, Right lane, (0.028) 6.669 207.08 def. Greg Stanfield,Bossier City LA, '09 GXP, (0.029) 6.674 206.04
Mike Edwards, Coweta OK, '09 GXP, Left lane, (0.044) 6.669 207.21 def. Kurt Johnson, Sugar Hill GA,'09 GXP, (0.071) 6.689 206.45
Jason Line, Mooresville NC, '09 GXP, Left lane, (0.040) 6.667 205.91 def. Richard Freeman, PaulsValley OK, '09 GXP, (0.078) 6.673 207.24
Erica Enders, New Orleans LA, '10 Cobalt, Left lane, (0.030) 6.638 207.53 def. Warren Johnson,Sugar Hill GA, '08 Cobalt, (0.128) 6.713 206.42
Greg Anderson, Mooresville NC, '09 GXP, Left lane, (0.093) 6.655 207.24 def. Steve Spiess,Manhattan IL, '10 Cobalt, (0.079) 6.722 204.17
Shane Gray, Denver NC, '09 GXP, Left lane, (0.041) 6.678 206.83 def. Larry Morgan, Newark OH, '11Mustang, (0.061) 6.841 177.79
Ron Krisher, Warren OH, '09 GXP, Left lane, (0.005) 6.713 207.40 def. Ronnie Humphrey, JacksonvilleNC, '08 GXP, (0.096) 6.703 204.79
Round 2:
S Gray, Left lane, (0.021) 7.245 202.33 def. R Krisher, (0.091) 18.831 41.13
J Line, Left lane, (0.059) 6.660 205.79 def. V Nobile, (0.035) 6.688 206.45
G Anderson, Left lane, (0.041) 6.659 206.23 def. R Brogdon, (0.065) 6.684 207.02
E Enders, Left lane, (0.045) 6.647 203.31 def. M Edwards, (0.000) 15.212 44.89
Round 3:
G Anderson, Left lane, (0.067) 6.659 207.11 def. S Gray, (0.047) 12.526 68.65
E Enders, Left lane, (0.027) 6.665 206.76 def. J Line, (0.033) 6.673 205.98
Round 4:
G Anderson, Right lane, (0.011) 6.670 207.18 def. E Enders, (0.031) 6.659 206.89
Low ET: Greg Anderson 6.586 seconds
Top Speed: Greg Anderson 209.14 MPH
MReeves
Pro-Stock
Jun 29, 2014 02:28 PM
MReeves
Funny Car
Jul 11, 2011 05:25 AM
MReeves
Stock Eliminator
Jul 10, 2011 12:46 PM
MReeves
Super Stock
Jul 10, 2011 08:39 AM
MReeves
Super Gas
Jul 8, 2011 09:13 AM
