NHRA Summer Nationals.... Topeka
Old May 20, 2011 | 05:47 PM
Fri, 20 May 2011, 06:28 PM
Pro Stock Qualifying Notes, Session #1
By Rick Green
TOPEKA, Kan. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals listing lane, driver name, elapsed time, top speed, and position in order following run:
Right Lane: Steve Kalkowski Runs 6.974/196.16, Now #1
Weather conditions: air temperature 74 degrees, relative humidity 70 percent, barometer 28.52 inches, adjusted altitude 3,428 feet, track temperature 86 degrees.
Kalkowski is making his season debut. He is straight down the groove.
Left Lane: Mark Hogan Runs 6.873/195.22, Now #2
Right Lane: Jim Yates Runs 6.808/203.19, Now #1
Yates is driving the Mark Martino car as he stayed home with his wife who is giving birth. Yates was real loose right at the hit. Hogan with his first pass of the season.
Left Lane: Dave River Runs 7.227/187.76, Now #5
Right Lane: Bob Yonke Runs 6.788/202.48, Now #1
Yonke is driving a car he browed from Richard Freeman. Yonke with a nice pass...
Left Lane: Richard Freeman Runs 6.720/204.98, Now #1
Right Lane: Kurt Johnson Runs 6.737/204.85, Now #2
This was a good looking drag race...Richard Freeman's incremental times: 60ft-0.993 sec., 330ft-2.809, 660ft-4.320/162.90 mph, 1,000ft-5.622.
Kurt Johnson's incremental times: 60ft-1.002 sec., 330ft-2.816, 660ft-4.331/161.73 mph, 1,000ft-5.637.
Left Lane: Warren Johnson Runs 6.735/204.85, Now #3
Right Lane: Larry Morgan Runs 6.706/205.66, Now #1
Morgan with a good pass...Larry Morgan's incremental times: 60ft-1.005 sec., 330ft-2.809, 660ft-4.315/163.16 mph, 1,000ft-5.612. WJ goes to the number three spot. Warren Johnson's incremental times: 60ft-1.007 sec., 330ft-2.818, 660ft-4.330/162.49 mph, 1,000ft-5.635.
Left Lane: V. Gaines Runs 10.885/82.76, Now #10
Right Lane: Shane Gray Runs 16.818/77.19, Now #11
Gray with violent tire shake as soon as he let the clutch out and clicked it off. Gaines with problems and pushed in a clutch.
Left Lane: Ronnie Humphrey Runs 6.690/205.63, Now #1
Right Lane: Ron Krisher Runs 6.725/205.47, Now #4
Krisher with some tire spin right at the hit...Humphrey with a real nice pass to go to the number one spot. Ronnie Humphrey's incremental times: 60ft-1.000 sec., 330ft-2.800, 660ft-4.301/163.57 mph, 1,000ft-5.597.
Left Lane: Allen Johnson Runs 6.660/207.05, Now #1
Right Lane: Erica Enders Runs 6.693/205.88, Now #3
This was a good side-by-side drag race...Allen Johnson's incremental times: 60ft-0.986 sec., 330ft-2.781, 660ft-4.280/163.73 mph, 1,000ft-5.572.
Erica Enders' incremental times: 60ft-0.994 sec., 330ft-2.801, 660ft-4.304/163.53 mph, 1,000ft-5.600.
Left Lane: Rodger Brogdon Runs 6.683/205.63, Now #2
Right Lane: Vincent Nobile Runs 6.711/205.41, Now #6
Brogdon with a real nice pass to go to the number two spot...Rodger Brogdon's incremental times: 60ft-0.995 sec., 330ft-2.791, 660ft-4.292/163.35 mph, 1,000ft-5.589. Nobile with a good pass to get into the top half of the show. Rodger Brogdon's incremental times: 60ft-0.995 sec., 330ft-2.791, 660ft-4.292/163.35 mph, 1,000ft-5.589.
Left Lane: Greg Stanfield Runs 6.724/205.19, Now #9
Right Lane: Mike Edwards Runs 6.678/206.48, Now #2
Edwards with the quickest 60-foot time of the session and he parlays that into a number two spot. Mike Edwards' incremental times: 60ft-0.981 sec., 330ft-2.786, 660ft-4.291/163.39 mph, 1,000ft-5.587. Stanfield gets into the show to start the weekend. Greg Stanfield's incremental times: 60ft-1.005 sec., 330ft-2.815, 660ft-4.324/162.82 mph, 1,000ft-5.626.
Left Lane: Greg Anderson Runs 6.688/205.44, Now #4
Right Lane: Jason Line Runs 12.610/68.07, Now #20
Line is real loose right at the hit and pushed the clutch in early. Anderson with a good pass to start the weekend. Greg Anderson's incremental times: 60ft-0.996 sec., 330ft-2.797, 660ft-4.298/163.51 mph, 1,000ft-5.594.
Timing data courtesy of CompuLink
From DragRaceCentral.com
Old May 21, 2011 | 03:10 AM
Round 2 Qualifying
Fri, 20 May 2011, 09:04 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
TOPEKA, Kan. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Shane Gray Runs 6.690/205.66, Now #5; Best prior run: 16.818/77.19, Was #21
Weather conditions: air temperature 72 degrees, relative humidity 70 percent, barometer 28.53 inches, adjusted altitude 3,282 feet, track temperature 77 degrees.
Gray launches hard and is straight down the groove to get in the top half of the field. Shane Gray's incremental times: 60ft-0.988 sec., 330ft-2.790, 660ft-4.297/162.80 mph, 1,000ft-5.595.
Left Lane: Jason Line Runs 6.719/205.85, Now #11; Best prior run: 12.610/68.07, Was #21
Right Lane: V. Gaines Runs 6.695/205.69, Now #8; Best prior run: 10.885/82.76, Was #20
Gaines was straight down the groove to get in the show. V. Gaines' incremental times: 60ft-0.994 sec., 330ft-2.797, 660ft-4.301/163.29 mph, 1,000ft-5.600. Line just gets in the show for now. Jason Line's incremental times: 60ft-0.984 sec., 330ft-2.816, 660ft-4.325/162.72 mph, 1,000ft-5.624. After the finish line there are no chutes for Line, but he has no problems getting the car stopped.
Left Lane: Steve Kalkowski Runs 6.938/196.85, Now #20; Best prior run: 6.974/196.16, Was #20
Right Lane: Dave River Runs 7.036/198.90, Now #21; Best prior run: 7.227/187.76, Was #21
Kalkowski improves, but not enough to get in the show. River also improves, but he won't get in the show.
Left Lane: Jim Yates Runs 6.767/204.26, Now #17; Best prior run: 6.808/203.19, Was #18
Right Lane: Mark Hogan Runs 12.873/66.21, Now #19; Best prior run: 6.873/195.22, Was #19
Hogan with problems as soon as the light turned green and he pushed in the clutch. Yates with a little wiggle in the first 60 feet, but still improves. Jim Yates' incremental times: 60ft-0.989 sec., 330ft-2.834, 660ft-4.356/161.69 mph, 1,000ft-5.665.
Left Lane: Bob Yonke Runs 6.751/203.55, Now #17; Best prior run: 6.788/202.48, Was #18
Right Lane: Warren Johnson Runs 6.688/206.01, Now #4; Best prior run: 6.735/204.85, Was #15
Johnson with a real nice looking pass to move up to the number four spot. Warren Johnson's incremental times: 60ft-0.992 sec., 330ft-2.791, 660ft-4.296/163.20 mph, 1,000ft-5.594. Yonke improves, but won't get in the show. Bob Yonke's incremental times: 60ft-0.989 sec., 330ft-2.808, 660ft-4.330/161.00 mph, 1,000ft-5.643.
Left Lane: Kurt Johnson Runs 6.712/205.29, Now #13; Best prior run: 6.737/204.85, Was #16
Right Lane: Greg Stanfield Runs 6.676/205.76, Now #2; Best prior run: 6.724/205.19, Was #14
Johnson improves, but will not get into the show. Kurt Johnson's incremental times: 60ft-0.995 sec., 330ft-2.804, 660ft-4.314/162.45 mph, 1,000ft-5.615. Stanfield launched hard and keep it hooked up to go to the number two spot. Greg Stanfield's incremental times: 60ft-0.987 sec., 330ft-2.782, 660ft-4.284/163.59 mph, 1,000ft-5.581.
Left Lane: Ron Krisher Runs 6.658/206.48, Now #1; Best prior run: 6.725/205.47, Was #16
Right Lane: Richard Freeman Runs 6.717/204.94, Now #15; Best prior run: 6.720/204.98, Was #15
Freeman with a slight improvement, but will not get in the show. Krisher with a great pass to go to the number one spot. Ron Krisher's incremental times: 60ft-0.978 sec., 330ft-2.775, 660ft-4.276/163.75 mph, 1,000ft-5.569.
Left Lane: Vincent Nobile Runs 6.693/206.39, Now #10; Best prior run: 6.711/205.41, Was #13
Right Lane: Ronnie Humphrey Runs 6.683/206.42, Now #5; Best prior run: 6.690/205.63, Was #9
Nobile makes a move in the right direction...Vincent Nobile's incremental times: 60ft-0.991 sec., 330ft-2.799, 660ft-4.305/163.28 mph, 1,000ft-5.601. Humphrey with a rel nice pass to get into the top half of the show. Ronnie Humphrey's incremental times: 60ft-1.001 sec., 330ft-2.801, 660ft-4.300/163.67 mph, 1,000ft-5.593.
Left Lane: Larry Morgan Runs 6.692/205.91, Now #10; Best prior run: 6.706/205.66, Was #13
Right Lane: Greg Anderson Runs 6.687/205.98, Now #7; Best prior run: 6.688/205.44, Was #8
Morgan improves and moves up the ladder three spots. Larry Morgan's incremental times: 60ft-0.999 sec., 330ft-2.800, 660ft-4.302/163.65 mph, 1,000ft-5.599. Anderson is just a tick better than earlier today and moves up one spot. Greg Anderson's incremental times: 60ft-0.996 sec., 330ft-2.797, 660ft-4.298/163.41 mph, 1,000ft-5.594.
Left Lane: Erica Enders Runs 6.687/206.54, Now #7; Best prior run: 6.693/205.88, Was #12
Right Lane: Rodger Brogdon Runs 6.651/206.67, Now #1; Best prior run: 6.683/205.63, Was #6
Enders with real nice pass to move up to the number seven spot. Erica Enders' incremental times: 60ft-0.995 sec., 330ft-2.798, 660ft-4.300/163.71 mph, 1,000ft-5.596. Brogdon with a great pass to go to the number one spot. Rodger Brogdon's incremental times: 60ft-0.981 sec., 330ft-2.773, 660ft-4.271/163.91 mph, 1,000ft-5.563.
Left Lane: Mike Edwards Runs 6.640/207.05, Now #1; Best prior run: 6.678/206.48, Was #5
Right Lane: Allen Johnson Runs 6.688/207.24, Now #4; Best prior run: 6.660/207.05, Was #3
Johnson makes a quick move toward the centerline, but reels it in. He runs top speed of the day. Allen Johnson's incremental times: 60ft-0.986 sec., 330ft-2.803, 660ft-4.306/163.39 mph, 1,000ft-5.600. Edwards with a great pass, straight down the groove to the number one spot. Mike Edwards' incremental times: 60ft-0.973 sec., 330ft-2.767, 660ft-4.263/164.25 mph, 1,000ft-5.553.
Old May 21, 2011 | 11:37 AM
Round 3 Qualifying
Sat, 21 May 2011, 01:00 PM
Pro Stock Qualifying Notes, Session #3
By Rick Green
TOPEKA, Kan. - Notes from round 3 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Mark Hogan Runs 7.159/201.40, Now #14; No Prior Run
Right Lane: Jim Yates Runs 6.733/204.70, Now #13; No Prior Run
Weather conditions: air temperature 76 degrees, relative humidity 60 percent, barometer 28.57 inches, adjusted altitude 3,473 feet, track temperature 94 degrees.
Hogan slows on the top end. Yates with his quickest pass of the weekend...Jim Yates' incremental times: 60ft-0.992 sec., 330ft-2.810, 660ft-4.326/162.00 mph, 1,000ft-5.632.
Left Lane: Dave River Runs 25.261/27.72, Now #16; No Prior Run
Right Lane: Bob Yonke Runs 6.744/203.71, Now #14; No Prior Run
River with problems right off the starting line and pushed in the clutch. Yonke with his quickest pass of the weekend. Bob Yonke's incremental times: 60ft-0.991 sec., 330ft-2.807, 660ft-4.326/161.21 mph, 1,000ft-5.638.
Left Lane: Richard Freeman Runs 6.745/204.94, Now #16; No Prior Run
Right Lane: Jason Line Runs 6.648/206.76, Now #2; No Prior Run
Freeman gets in on the bump. Line gets it to hook up and goes to the number two spot. Jason Line's incremental times: 60ft-0.985 sec., 330ft-2.774, 660ft-4.269/163.97 mph, 1,000ft-5.559.
Left Lane: V. Gaines Runs 6.687/205.63, Now #10; No Prior Run
Right Lane: Kurt Johnson Runs 6.705/204.94, Now #15; No Prior Run
Both of these guys get in the show..Gaines ties Anderson's E.T. but gives up the spot based on the mph. V. Gaines' incremental times: 60ft-0.995 sec., 330ft-2.793, 660ft-4.295/163.37 mph, 1,000ft-5.592. Johnson with his quickest pass of the weekend. Kurt Johnson's incremental times: 60ft-0.990 sec., 330ft-2.795, 660ft-4.305/162.35 mph, 1,000ft-5.607.
Left Lane: Warren Johnson Runs 6.691/206.32, Now #12; Best prior run: 6.688/206.01, Was #11
Right Lane: Vincent Nobile Runs 6.680/206.42, Now #7; Best prior run: 6.693/206.39, Was #14
Nobile with his quickest pass of the weekend to get into the to half of the show. Vincent Nobile's incremental times: 60ft-0.990 sec., 330ft-2.788, 660ft-4.290/163.20 mph, 1,000ft-5.587. Johnson slows from his time from yesterday. Warren Johnson's incremental times: 60ft-0.995 sec., 330ft-2.795, 660ft-4.299/163.47 mph, 1,000ft-5.598.
Left Lane: Allen Johnson Runs 6.650/206.83, Now #3; Best prior run: 6.660/207.05, Was #5
Right Lane: Larry Morgan Runs 6.698/205.69, Now #14; Best prior run: 6.692/205.91, Was #14
Johnson matches Line's short time, and is just a couple ticks behind Line for third place. Allen Johnson's incremental times: 60ft-0.985 sec., 330ft-2.774, 660ft-4.270/164.15 mph, 1,000ft-5.561. No help here for Morgan...Larry Morgan's incremental times: 60ft-0.999 sec., 330ft-2.800, 660ft-4.303/163.20 mph, 1,000ft-5.603.
Left Lane: Greg Anderson Runs 6.696/205.44, Now #11; Best prior run: 6.687/205.98, Was #10
Right Lane: Shane Gray Runs 6.674/206.07, Now #6; Best prior run: 6.690/205.66, Was #13
Gray with a real nice pass, his quickest of the weekend to get into the top half of the show. Shane Gray's incremental times: 60ft-0.988 sec., 330ft-2.784, 660ft-4.285/163.67 mph, 1,000ft-5.581. Anderson slows from his time from yesterday and gets bumped back a spot. Greg Anderson's incremental times: 60ft-0.996 sec., 330ft-2.800, 660ft-4.303/163.08 mph, 1,000ft-5.601.
Left Lane: Ronnie Humphrey Runs 6.658/206.35, Now #6; Best prior run: 6.683/206.42, Was #9
Right Lane: Erica Enders Runs 6.685/206.83, Now #10; Best prior run: 6.687/206.54, Was #10
Enders with her quickest pass of the weekend, but will stay in the number ten spot. Erica Enders' incremental times: 60ft-1.001 sec., 330ft-2.800, 660ft-4.300/163.55 mph, 1,000ft-5.595. Humphrey with real nice pass, straight down the groove with his quickest pass of the weekend. Ronnie Humphrey's incremental times: 60ft-0.990 sec., 330ft-2.779, 660ft-4.275/163.83 mph, 1,000ft-5.568.
Left Lane: Greg Stanfield Runs 6.694/205.57, Now #8; Best prior run: 6.676/205.76, Was #8
Right Lane: Ron Krisher Runs 6.677/206.86, Now #5; Best prior run: 6.658/206.48, Was #5
no help here for Stanfield and he will stay in the number five spot. Greg Stanfield's incremental times: 60ft-0.996 sec., 330ft-2.796, 660ft-4.300/163.41 mph, 1,000ft-5.599. Krisher with another good pass, but will not improve...Ron Krisher's incremental times: 60ft-0.989 sec., 330ft-2.790, 660ft-4.294/163.41 mph, 1,000ft-5.588.
Left Lane: Rodger Brogdon Runs 6.680/205.98, Now #4; Best prior run: 6.651/206.67, Was #4
Right Lane: Mike Edwards Runs 6.654/206.76, Now #1; Best prior run: 6.640/207.05, Was #1
Edwards with the quickest short time and runs the third quickest pass of the session. Mike Edwards' incremental times: 60ft-0.981 sec., 330ft-2.775, 660ft-4.273/164.05 mph, 1,000ft-5.565. Brogdon with another good looking pass, but will not improve. Rodger Brogdon's incremental times: 60ft-0.991 sec., 330ft-2.791, 660ft-4.292/163.49 mph, 1,000ft-5.588.
Old May 22, 2011 | 11:44 AM
Round 1 Eliminations
Sunday
Results for Elimination Round 1
TOPEKA, Kan. - SUMMIT FastNews - Results of round 1 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals:
W/L Driver R-Time E-Time Speed
(W) Greg Stanfield (Nitrofish GXP) 0.000 6.725 205.91
(L) Vincent Nobile (Mountainview Tire Avenger) 0.015 6.718 206.23
Weather conditions: air temperature 81 degrees, relative humidity 51 percent, barometer 28.49 inches, adjusted altitude 3,827 feet, track temperature 114 degrees. Nobile is 2 - 0 against Stanfield in prior events. Stanfield with a perfect light and has the power to hold on for the hole shot win. Greg Stanfield's MOV: 0.0087 seconds (approximately 3 feet). Stanfield with his quickest pass of the weekend for the win.
(W) Shane Gray (Service Central GXP) 0.052 6.684 206.67
(L) Erica Enders (ZaZa Energy Cobalt) 0.049 17.208 47.96
This is the first time Enders and Gray have faced each other in eliminations. Enders with a slight starting line advantage, but then had problems and pushed in the clutch. Gray was loose right off the starting line, but stayed with for the win.
(W) Greg Anderson (Summit Racing Equipment GXP) 0.037 6.687 206.29 (L) Ronnie Humphrey (Genuine Hot Rod Hardware G 0.052 6.683 206.32
Anderson is 6 - 0 against Humphrey in prior events. Anderson is 21 and 5 in overall round wins and loses here. Anderson with the starting line advantage and the power to hold on for hole shot win. Greg Anderson's MOV: 0.0119 seconds (approximately 4 feet).
(W) Rodger Brogdon (The Racer's Edge GXP) 0.048 6.677 206.92
(L) Warren Johnson (K&N Filters Cobalt) 0.050 6.785 206.35
Brogdon is 2 - 1 against Johnson in prior events. Brogdon with a slight starting line advantage and runs quick E.T. of the round for the win.
(W) Jason Line (Summit Racing Equipment GXP) 0.048 6.665 206.76
(L) Kurt Johnson (Mark Christopher Auto Center 0.051 6.708 205.76
Line is 21 - 15 against Johnson in prior events. Line is out of the gate first and runs the quickest pass of the round for the win...Jason Line's incremental times: 60ft-0.990 sec., 330ft-2.787, 660ft-4.285/163.85 mph, 1,000ft-5.577. Line will have lane choice against Gray in the next round.
(W) Richard Freeman (Elite Motorsports GXP) 0.069 6.753 205.47
(L) Mike Edwards (Penhall/K&N/Interstae GXP) 0.065 6.760 206.51
Edwards is 1 - 0 against Freeman in prior events. Edwards with the slight starting line advantage, but Freeman had the difference made up by 200 feet and takes the upset win by 0.0039 seconds (approximately 14 inches). Freeman will give up lane choice against Stanfield in the next round.
(W) Allen Johnson (Mopar/J & J Racing Avenger) 0.013 6.711 206.20
(L) Larry Morgan (Lucas Oil/Summit Mustang) 0.074 6.706 206.10
Johnson is 17 - 9 against Morgan in prior events. Johnson with the starting line advantage and the power to hold on for the hole shot win. Johnson will give up lane choice to Anderson in the next round.
(W) V. Gaines (Kendall Oil Avenger) 0.036 6.700 205.57
(L) Ron Krisher (Valvoline GXP) 0.087 6.690 206.95
Gaines and Krisher have each won 7 times against the other in prior events. Gaines and Krisher have each won 7 times against the other in prior events. Gaines with the starting line advantage and the power to hold for the hole shot win. Gaines will give up lane choice to Brogdon in the next round.
From NHRA.com
Old May 22, 2011 | 11:47 AM
Round 2 Eliminations
Sunday
Results for Elimination Round 2
TOPEKA, Kan. - SUMMIT FastNews - Results of round 2 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals:
(W) Greg Stanfield (Nitrofish GXP) 0.024 6.693 206.32
(L) Richard Freeman (Elite Motorsports GXP) 0.059 15.021 55.93
Weather conditions: air temperature 82 degrees, relative humidity 45 percent, barometer 28.49 inches, adjusted altitude 3,859 feet, track temperature 122 degrees. This is the first time Freeman and Stanfield have faced each other in eliminations. Freeman made a quick move toward the centerline as soon as he let the clutch out.
(W) Greg Anderson (Summit Racing Equipment GXP) 0.023 6.715 204.17
(L) Allen Johnson (Mopar/J & J Racing Avenger) 0.023 6.762 203.58
Anderson is 29 - 10 against Johnson in prior events. They left together and then it was all Anderson for the win. Greg Anderson's MOV: 0.0474 seconds (approximately 14 feet).
(W) Rodger Brogdon (The Racer's Edge GXP) 0.026 6.707 206.73
(L) V. Gaines (Kendall Oil Avenger) 0.046 6.688 205.76
Gaines and Brogdon have each won 1 times against the other in prior events. Brogdon is out of the gate first and has the power to hold on for the hole shot win. Rodger Brogdon's MOV: 0.0017 seconds (approximately 6 inches). Brogdon will give up lane choice to stanfield in the semifinal.
(W) Shane Gray (Service Central GXP) 0.038 6.673 206.64
(L) Jason Line (Summit Racing Equipment GXP) 0.023 6.690 206.83
Line is 4 - 1 against Gray in prior events. Line with the starting line advantage, but Gray has the difference made up by 1000 feet when Line spun the tires. Gray with the quickest pass of the round for the win. He will have lane choice over Anderson in the semifinal.
From NHRA.com
Old May 22, 2011 | 05:56 PM
Round 3
Sunday
Results for Elimination Round 3
TOPEKA, Kan. - SUMMIT FastNews - Results of round 3 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals:
(W) Greg Stanfield (Nitrofish GXP) 0.022 6.705 206.32
(L) Rodger Brogdon (The Racer's Edge GXP) -0.027(R) 7.301 142.64
Weather conditions: air temperature 83 degrees, relative humidity 40 percent, barometer 28.48 inches, adjusted altitude 3,858 feet, track temperature 124 degrees. Stanfield is 4 - 2 against Brogdon in prior events. Brogdon is jut too quick on the tree and turned on the red light. Stanfield goes into the final...
(W) Shane Gray (Service Central GXP) 0.050 6.710 206.26
(L) Greg Anderson (Summit Racing Equipment GXP) 0.034 6.799 204.73
Anderson is 5 - 0 against Gray in prior events. Anderson with the starting line advantage, but Gray has the difference made up by the time they go by the Christmas tree. Gray will give up lane choice to Stanfield in the final.
Old May 22, 2011 | 05:58 PM
Final
Sunday
Results for Final Round
TOPEKA, Kan. - SUMMIT FastNews - Results of final, round 4 eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 23rd annual Summer Nationals:
(W) Shane Gray (Service Central GXP) 0.047 6.679 206.95
(L) Greg Stanfield (Nitrofish GXP) 0.040 6.693 206.29
Weather conditions: air temperature 82 degrees, relative humidity 42 percent, barometer 28.46 inches, adjusted altitude 3,849 feet, track temperature 124 degrees. Stanfield is 3 - 0 against Gray in prior events and this is the first time they have faced each other in a final round. Stanfield with the starting line advantage and the lead until right before half track. Gray gets the lead at half track and takes the win...Shane Gray's MOV: 0.0078 seconds (approximately 2 feet). This is Gray's second National event win.
MReeves
Stock Eliminator
May 22, 2011 05:49 PM
MReeves
Super Stock
May 22, 2011 09:02 AM
MReeves
Funny Car
May 23, 2010 03:12 PM
MReeves
Pro-Stock
May 23, 2010 03:09 PM
MReeves
Super Stock
May 21, 2010 03:05 PM
