Winternationals 2011 Pomona
Thu, 24 Feb 2011, 04:24 PM
Pro Stock Qualifying Notes, Session #1
By David Gerard
POMONA, Calif. - Notes from round 1 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 51st annual Kragen O'Reilly NHRA Winternationals presented by Valvoline listing lane, driver name, elapsed time, top speed, and position in order following run:
Left Lane: Buddy Perkinson Runs 6.593/209.14, Now #1
Right Lane: Richard Freeman Runs 24.481/34.15, Now #2
12:55 p.m. Weather conditions: air temperature 65 degrees, relative humidity 41 percent, barometer 28.06 inches, adjusted altitude 1,806 feet, track temperature 78 degrees.
Perkinson sets the mark for the field with a big ET and MPH on a super pass for the Mustang.
Freeman kicked the tires at the green and slowed.
Buddy Perkinson's incremental times: 60ft-0.987 sec., 330ft-2.763, 660ft-4.242/166.35 mph, 1,000ft-5.516.
Left Lane: Vincent Nobile Runs 24.607/32.87, Now #4
Right Lane: Erica Enders Runs 6.553/211.69, Now #1
Nobile's Avenger darts around off the line and he coasts on down.
Enders makes a strong pass with a new career best ET and MPH and ups the ante for the rest of the field.
Erica Enders' incremental times: 60ft-0.991 sec., 330ft-2.758, 660ft-4.225/168.22 mph, 1,000ft-5.489.
Left Lane: Ronnie Humphrey Runs 6.598/210.44, Now #3
Right Lane: Larry Morgan Runs 6.602/209.69, Now #4
Two strong passes and Morgan's Mustang runs right behind a stronger Humphrey.
Ronnie Humphrey's incremental times: 60ft-0.993 sec., 330ft-2.782, 660ft-4.258/166.87 mph, 1,000ft-5.527.
Larry Morgan's incremental times: 60ft-0.993 sec., 330ft-2.781, 660ft-4.257/166.83 mph, 1,000ft-5.529.
Left Lane: Bob Yonke Runs 14.166/61.25, Now #6
Right Lane: Warren Johnson Runs 6.572/210.80, Now #2
Yonke's GXP is sporting a wrap with the Rango movie theme. The crew is in red and white flowered hawaiian themed shirts Doesn't help, as he slows off the line.
Clean pass for Johnson and he moves into the new #2 spot on the ladder. Nice run!
Warren Johnson's incremental times: 60ft-0.984 sec., 330ft-2.756, 660ft-4.230/167.22 mph, 1,000ft-5.501.
Left Lane: Kurt Johnson Runs 6.571/210.21, Now #2
Right Lane: V. Gaines Runs 7.103/204.42, Now #7
Gaines car stumbles off the line and then picks up going down the track.
Johnson bumps Dad down a spot with a straight pass right down the track.
Kurt Johnson's incremental times: 60ft-0.978 sec., 330ft-2.749, 660ft-4.226/166.79 mph, 1,000ft-5.498.
V. Gaines' incremental times: 60ft-1.009 sec., 330ft-3.133, 660ft-4.697/160.18 mph, 1,000ft-6.007.
Left Lane: Rodger Brogdon Runs 6.600/209.79, Now #7
Right Lane: Ron Krisher Runs 6.562/211.26, Now #2
Brogdon's GXP has a new Racer's Edge theme.
Krisher retakes the popular #2 spot with ease. Brogdon has a clean pass into the current top half off the field.
Ron Krisher's incremental times: 60ft-0.991 sec., 330ft-2.759, 660ft-4.230/167.72 mph, 1,000ft-5.495.
Left Lane: Allen Johnson Runs 6.568/211.36, Now #3
Right Lane: Jason Line Runs 6.597/210.44, Now #7
Enders stays #1, as these two can't up the mark.
They card good ET's, just not good enough.
Allen Johnson's incremental times: 60ft-0.984 sec., 330ft-2.758, 660ft-4.232/167.30 mph, 1,000ft-5.501.
Jason Line's incremental times: 60ft-0.993 sec., 330ft-2.777, 660ft-4.253/166.62 mph, 1,000ft-5.525.
Left Lane: Shane Gray Runs 6.747/209.88, Now #11
Right Lane: Mike Edwards Runs 12.586/59.78, Now #13
Bob Yonke is on the bump spot at 14.166.
Edwards blows off the tires at the hit.
Gray makes a clean pass, but doesn't have the tuneup for a top half of the field result.
Shane Gray's incremental times: 60ft-1.147 sec., 330ft-2.924, 660ft-4.400/167.03 mph, 1,000ft-5.673.
Left Lane: Greg Stanfield Runs 6.562/210.77, Now #3
Right Lane: Greg Anderson Runs 6.569/210.60, Now #5
V. Gaines is on the bump spot at 7.103.
Last pair of the session and our 2010 #1 and #2 ProStockers come to the line, with Enders in their sights.
Two straight pass with representative incrementals, but they can only manage a #3 and #5 result. It certainly looked better.
Greg Stanfield's incremental times: 60ft-0.985 sec., 330ft-2.752, 660ft-4.223/167.70 mph, 1,000ft-5.492.
Greg Anderson's incremental times: 60ft-0.991 sec., 330ft-2.761, 660ft-4.231/167.36 mph, 1,000ft-5.500.
1:17 p.m. Erica Enders stays number one at 6.553. Larry Morgan is on the bump spot at 6.602.
Timing data courtesy of CompuLink
From DRC.com
By David Gerard
From DRC.com
Round 2 Qualifying
Sat, 26 Feb 2011, 05:46 PM
Pro Stock Qualifying Notes, Session #2
By Rick Green
POMONA, Calif. - Notes from round 2 qualifying in Pro Stock at the NHRA Full Throttle Drag Racing Series, 51st annual Kragen O'Reilly NHRA Winternationals presented by Valvoline listing lane, driver name, elapsed time/top speed this round, position in order following run, best prior elapsed time/speed, and position in order prior to run:
Left Lane: Richard Freeman Runs 6.640/208.78, Now #14; No Prior Run
Right Lane: Vincent Nobile Runs 6.612/210.54, Now #13; No Prior Run
Weather conditions: air temperature 58 degrees, relative humidity 38 percent, barometer 28.61 inches, adjusted altitude 1,842 feet, track temperature 82 degrees.
Freeman made a quick move toward the wall, but reeled it in. Nobile with a good pass, straight down the groove. Vincent Nobile's incremental times: 60ft-1.004 sec., 330ft-2.790, 660ft-4.269/166.76 mph, 1,000ft-5.541.
Left Lane: Mike Edwards Runs 28.456/28.45, Now #16; No Prior Run
Right Lane: Bob Yonke Runs 12.562/70.20, Now #15; No Prior Run
Edwards just blew the tires off as soon as he let the clutch out and pushed in the clutch. Yonke got real loose and was off the throttle by 200 feet.
Left Lane: V. Gaines Runs 6.564/209.95, Now #4; No Prior Run
Right Lane: Shane Gray Runs 6.614/209.04, Now #15; No Prior Run
Gaines launched hard and was straight down the groove with a great looking pass. V. Gaines' incremental times: 60ft-0.978 sec., 330ft-2.749, 660ft-4.223/166.99 mph, 1,000ft-5.492. Gray gets into the field for now. Shane Gray's incremental times: 60ft-0.986 sec., 330ft-2.772, 660ft-4.257/166.01 mph, 1,000ft-5.536.
Left Lane: Larry Morgan Runs 6.588/209.95, Now #9; Best prior run: 6.602/209.69, Was #13
Right Lane: Rodger Brogdon Runs 6.601/210.01, Now #13; Best prior run: 6.600/209.79, Was #12
Morgan with a real nice pass to move up the ladder. Larry Morgan's incremental times: 60ft-0.982 sec., 330ft-2.759, 660ft-4.239/166.15 mph, 1,000ft-5.514. No help here for Brogdon...Rodger Brogdon's incremental times: 60ft-1.002 sec., 330ft-2.782, 660ft-4.259/166.87 mph, 1,000ft-5.530.
Left Lane: Jason Line Runs 6.590/210.54, Now #11; Best prior run: 6.597/210.44, Was #11
Right Lane: Ronnie Humphrey Runs 6.584/210.97, Now #9; Best prior run: 6.598/210.44, Was #12
They were side by side all the way down the the quarter mile...Humphrey gets there first. Jason Line's incremental times: 60ft-0.989 sec., 330ft-2.769, 660ft-4.246/166.60 mph, 1,000ft-5.519.
Ronnie Humphrey's incremental times: 60ft-0.988 sec., 330ft-2.772, 660ft-4.247/166.93 mph, 1,000ft-5.516.
Left Lane: Warren Johnson Runs 6.641/209.65, Now #8; Best prior run: 6.572/210.80, Was #8
Right Lane: Buddy Perkinson Runs 6.643/207.88, Now #12; Best prior run: 6.593/209.14, Was #12
No help here for either of these guys...Warren Johnson's incremental times: 60ft-0.987 sec., 330ft-2.795, 660ft-4.286/165.70 mph, 1,000ft-5.565.
Buddy Perkinson's incremental times: 60ft-0.987 sec., 330ft-2.781, 660ft-4.273/164.93 mph, 1,000ft-5.559.
Left Lane: Greg Anderson Runs 6.556/210.77, Now #2; Best prior run: 6.569/210.60, Was #6
Right Lane: Kurt Johnson Runs 6.599/209.52, Now #7; Best prior run: 6.571/210.21, Was #7
Anderson with a great looking pass to go to the number two spot. Greg Anderson's incremental times: 60ft-0.981 sec., 330ft-2.747, 660ft-4.218/167.45 mph, 1,000ft-5.487. No help here for Johnson and he will stay number seven. Kurt Johnson's incremental times: 60ft-0.987 sec., 330ft-2.765, 660ft-4.248/166.11 mph, 1,000ft-5.524.
Left Lane: Ron Krisher Runs 6.576/210.70, Now #4; Best prior run: 6.562/211.26, Was #3
Right Lane: Allen Johnson Runs 6.561/210.80, Now #3; Best prior run: 6.568/211.36, Was #6
This was a great side-by-side drag race with the second and fourth quickest passes of the round. Ron Krisher's incremental times: 60ft-0.988 sec., 330ft-2.762, 660ft-4.237/167.24 mph, 1,000ft-5.507.
Allen Johnson's incremental times: 60ft-0.981 sec., 330ft-2.748, 660ft-4.223/167.18 mph, 1,000ft-5.492.
Left Lane: Erica Enders Runs 6.590/209.95, Now #1; Best prior run: 6.553/211.69, Was #1
Right Lane: Greg Stanfield Runs 6.591/209.46, Now #5; Best prior run: 6.562/210.77, Was #5
A couple good looking passes, but they will not improve on their runs from Thursday. Erica Enders' incremental times: 60ft-0.982 sec., 330ft-2.760, 660ft-4.241/166.35 mph, 1,000ft-5.516.
Greg Stanfield's incremental times: 60ft-0.981 sec., 330ft-2.759, 660ft-4.241/166.23 mph, 1,000ft-5.516.
Erica holds on the the number one spot.
From DRC.Com
By Rick Green
From DRC.Com
Summary of Eliminations
Sun, 27 Feb 2011, 10:04 PM
Summary of Eliminations in Pro Stock
POMONA, Calif. - Summary of eliminations in Pro Stock at the NHRA Full Throttle Drag Racing Series, 51st annual Kragen O'Reilly NHRA Winternationals presented by Valvoline:
Round 1:
Ronnie Humphrey, Jacksonville NC, '10 GXP, Right lane, (0.045) 11.738 75.52 def. Warren Johnson,Sugar Hill GA, '10 GXP, (-0.010 foul) 6.573 211.76
Jason Line, Mooresville NC, '10 GXP, Right lane, (0.002) 6.538 211.89 def. V. Gaines, Lakewood CO,'10 Avenger, (0.043) 6.646 210.24
Greg Stanfield, Bossier City LA, '09 GXP, Left lane, (0.020) 6.566 211.43 def. Buddy Perkinson,Hopewell VA, '10 Mustang, (0.045) 7.664 128.18
Ron Krisher, Warren OH, '10 GXP, Left lane, (0.054) 6.533 212.06 def. Rodger Brogdon, Tomball TX,'10 GXP, (0.045) 6.576 211.53
Greg Anderson, Morresville NC, '10 GXP, Left lane, (0.030) 6.540 211.86 def. Shane Gray, Denver NC,'10 GXP, (0.035) 6.588 209.69
Erica Enders, New Orleans LA, '11 Cobalt, Left lane, (0.023) 6.545 212.43 def. Richard Freeman,Pauls Valley OK, '09 GXP, (0.046) 8.088 131.00
Vincent Nobile, Dix Hills NY, '10 Avenger, Right lane, (0.002) 6.561 211.73 def. Allen Johnson,Greeneville TN, '11 Avenger, (0.055) 6.559 212.39
Kurt Johnson, Sugar Hill GA, '10 GXP, Left lane, (0.063) 6.585 210.77 def. Larry Morgan, Newark OH,'10 Mustang, (-0.018 foul) 12.002 70.49
Round 2:
R Humphrey, Right lane, (0.070) 12.640 69.36 def. E Enders, NT-Broke Before Staging
G Anderson, Left lane, (0.035) 6.531 211.00 def. K Johnson, (0.029) 6.587 209.72
J Line, Left lane, (0.026) 6.535 211.66 def. V Nobile, (0.023) 6.555 211.30
G Stanfield, Right lane, (0.016) 6.561 210.80 def. R Krisher, (0.047) 6.629 210.90
Round 3:
G Stanfield, Left lane, (0.038) 6.538 210.90 def. R Humphrey, (0.073) 6.561 211.56
J Line, Right lane, (0.001) 6.532 211.76 def. G Anderson, (0.048) 6.563 211.10
Round 4:
J Line, Left lane, (0.041) 6.529 211.89 def. G Stanfield, (0.020) 6.595 210.70
Low ET: Jason Line 6.529 seconds
Top Speed: Erica Enders 212.43 MPH
From DRC.com
Round 1:
Round 2:
Round 3:
Round 4:
From DRC.com
