1935 dodge truck build
Old Aug 16, 2013 | 02:21 PM
hbmopar's Avatar
Hey there first off I'm a new member! atriotic: I'm restoring a 1935 dodge truck, I need help on a couple of things, It's all original. I'm going to running it 12v originally 6v so I'm running new gauges, the original speedo was mechanical, new one is electric, what parts do I need to make this work? Second off the speedo also has a tach on it, originally truck had no tach, do I need to find diff gauges that's has no tach or is there a way to run the truck with a tach? If I have any other questions more will be posted at a later date.
Thank you,
Hbmopar (ryan)
Old Aug 16, 2013 | 04:13 PM
HB Mopar.... I'm not clear on what you are installing....
But what i'm am getting is, you are going from a 6 volt system to a 12 volt system?
On the electric speedo side of the question.... there is a adapter that screws in place of the cable to work with the tach....
I have done Autometers and S/W. But I have not done the Dakota Gauge setup yet.
Hope i'm not to far off base and adding more confusion to your quest?
Old Aug 16, 2013 | 05:02 PM
moe7404's Avatar
what? no rat rod?
LibbeysClsscCar
Jan 30, 2014 04:16 PM
mopar49
Jul 1, 2013 03:16 PM
madman23420
May 31, 2012 02:23 AM
The Creed
22
May 29, 2011 02:17 PM
mopardrt
Jun 6, 2010 12:50 AM
