1940 Plymouth Electrical Problem
Old Dec 29, 2013 | 04:27 PM
Plymouthguy's Avatar
(1940 Plymouth with 1966 Valiant Motor) I replaced my 60 amp alternator along with the 2 belts. When I hooked everything back up and tried to start the car it turned over once and then the electrical system went dark. Seemed as if I had my belts too tight and blew a fuse. Problem is, I don't know which fuse would cause an entire system shutdown. Need some help!
Old Dec 29, 2013 | 04:54 PM
No way possible for us to know that. A 12V, modern engine conversion in a 40 car? Are you kidding? We don't have a crystal ball, nor have any way in the world of knowing how that car might be wired.
You still have the original ammeter? Might be a problem there. I doubt the alternator is the cause of the trouble, unless it's defective, that is, a massive internal short, which "could" have caused fuses / fuse links to blow
If I were there, wherever "there" is, we'd have this found in short order.
I would disconnect the battery and put a lamp in series with the battery. This is to protect everything, especially wiring, in case of a short.. Use a large heavy lamp such as a turn signal or headlamp. If the lamp lights bright, you have a heavy load or short.
Now take a test lamp or multimeter and find out where there is / is not power.
ZombiePopper's Avatar
Being a 40 it would've been a 6v system, wiring and components originally.
What has been replaced?
Old Dec 29, 2013 | 06:01 PM
Check the grounds...
Also check the starter relay for power...
imac08
Oct 31, 2012 09:32 AM
stevedorry
Sep 15, 2012 04:45 PM
Steffany
Apr 17, 2012 11:42 AM
76 Doba
Feb 28, 2011 02:15 PM
