2001 Ram 1500 Bearing Hub Stuck
Old Oct 4, 2009 | 11:01 AM
crwchf16's Avatar
Question 2001 Ram 1500 Bearing Hub Stuck
Does anyone have any tricks for removing the front-wheel bearing hub assembly from a Dodge Ram 1500 4x4? I can't budge this thing!
Old Oct 4, 2009 | 11:12 AM
scotts74birds's Avatar
Does it have the 3, 12pt bolt heads on the back of the steering knuckle?
Old Oct 5, 2009 | 01:52 AM
I have heard using a pickle fork works very well. Or a slide hammer.
Old Oct 5, 2009 | 03:48 PM
Yes, the slide hammer or puller works, but only if you are replacing the bearing. If just to access the wheel u-joint, then no, it can cause damage. I have used a sacrificial 12pt japanese socket on the 3 bolts and hammered it loose from there. done it about 4 times and havent damaged the bolts. Never had an issue with the driveshaft splines coming free of the hub either.
Old Oct 5, 2009 | 09:16 PM
crwchf16's Avatar
3-bolts, yep
The truck does have the 3 12-point head bolts in it. I removed those easily enough but the assembly itself is so solidly frozen in there after 100k+ of driving that it won't move. I'm trying to pull it so I can replace a u-joint but as long as it's out I'm going to replace the hub too. I've tried beating on the sides and on the heads of the bolts but it's not moving.
Old Oct 6, 2009 | 03:35 AM
If you have heat, put that to it. Otherwise, you might have to cut the ball joints and press the hub out.
Old Oct 6, 2009 | 03:07 PM
If the bearing is toast, then yes, a slidehammer. Friends have also used air chisels, but that destroys the brake baking plate.
Old Oct 7, 2009 | 01:17 AM
crwchf16's Avatar
I'm at the point where dynamite is sounding good
Old Oct 7, 2009 | 03:29 AM
Backing plates are over rated.
shiftlow
Nov 5, 2011 08:11 PM
scotts74birds
Sep 1, 2011 03:15 AM
crwchf16
Oct 11, 2009 12:47 AM
crwchf16
Sep 22, 2009 08:49 AM
johnny4915
Nov 29, 2008 05:05 AM
