360 build myself
Old Jun 5, 2009 | 05:57 PM
Polaradude's Avatar
My only reservation is the KB pistons, I am not a big fan. Welcome to the Forum man, Sealed Power is a good slug. What casting # are the 360's ?
Old Jun 5, 2009 | 06:18 PM
scotts74birds's Avatar
I dont think you will come anywhere close to the hp you want with that combo, X2 on the pistons. Pretty mild build. 100hp shot of nitrous would do it. What car for this combo? trans?
Old Jun 5, 2009 | 07:38 PM
whats the trans/rear end?
junk those KB pistons!!!!!!
Old Jun 5, 2009 | 07:47 PM
Crazy4Carz.Com's Avatar
Diamond pistons. Forged and all ready for spray! And to get the HP you want you'll need WAY more cam and gobs of head work.
Old Jun 8, 2009 | 06:27 PM
theomahamoparguy's Avatar
well, you,d be surprised of the power of a near stock 360. I wouldn't think about the HP numbers right away. Just build a strong bottom end, do a decent v alve job on the heads and be careful with the assembly. Later down the road you can put on some better heads, cam etc. You'll be fine with the combo you have on paper but if you want 450-500 hp, more will be required. save up for it and do it later.
What car will this be going in?
Old Jun 9, 2009 | 02:26 PM
whats your trans and rear end?
Old Jun 10, 2009 | 09:48 PM
Dibs on the satty body!
Old Jun 11, 2009 | 04:35 PM
make sure you read this thread:
https://moparforums.com/forums/f62/o...33/index2.html
Old Jun 11, 2009 | 04:38 PM
I'm with theomaha on this one. Only thing Is though, while you have the motor aparts, it would be a good diea to install the cam that you want now but thats just me.
Old Jun 13, 2009 | 12:35 PM
Originally Posted by irishman
i currently have the engine and everything in the machine shop, i need to know for what i wanna get do i need to replace the cam, that would put different valves/springs in heads, intake. if so what is the recommendation on cam and intake
I would go with a Comp Cams 262 H high energy cam. Would work extremely well in a 360. Would work good with your intake.
Old Jun 13, 2009 | 12:42 PM
Comp cams can recommend the best springs to go with the cam. But definitly go with the recommendations of the cam manufacturer. Id put the 2.02 intake valves in it and leave the stock exhaust valves. [that way you do not disturb the hardened exhaust valve seats, the intake seats were not hardened just the exhaust seats] I like the one piece stainless intake valves by Ferria {spelling?}.
Old Jun 15, 2009 | 06:58 PM
Performer Rpm air gap. Still callin dibs on the satty body!
Old Jun 15, 2009 | 07:50 PM
isnt a 750 cfm too big for a 360?
Old Jun 20, 2009 | 12:01 PM
Well you could go with the 268/280 it has 477 lift on the intake and 480 on the exhaust Part num. CCA-CL20-223-3 from summit racing. Its a cam and lifter package and think it retails for about $186 probably good for 5800-6000 rpm's if set up with right intake/carb.
The other one that I mentioned was the 262/270 with 462 lift on the intake and 470 on the exhaust . Alittle bit milder but would be a torque producer. Probably could ring it out to 5600-5800 R's.
It is part num. CCA-CL20-222-3. Has the same price and is also a cam and lifter package . Both are ground on 110 deg. centerlines I believe.
I think both of these would work good for a 360 with the stock crank.
Old Jun 20, 2009 | 12:46 PM
a 750 vacuum secondary holley is not too big for a 360 and you can make a 750 double pumper work too but it will be "temperimental" {kinda touchy} on the street.
Intakes;1. eldebr. rpm air gap/2. Weiand Stealth air strike/ or 3. crosswind intake made by professional products-RPM Machine
ALSO Summit racing has thier own "air gap type" manifold that looks to be very much the same as the Eldebrock RPM air gap for a little bit cheaper but I personally haven't heard much about it in terms of comparison.
Old Jun 21, 2009 | 11:27 AM
  #24
DUST360's Avatar
Junior Member
your engine with make 300ish hp, maybee. put magnum heads or eddys on. and a bigger cam 2 make your goal hp. good luck
Old Jul 10, 2009 | 08:03 AM
  #27
Morrigan_Aria's Avatar
Hell kitten
I'm a b body fan too, but if I were you, I'd cram that motor into an A body. Not like I should talk, my Belvedere sports a 318.
Old May 29, 2010 | 03:37 PM
  #29
christineman's Avatar
building a 360 and sure could use some advice here......
Im buildling a 360 up.. not a magnum..want it streetable. I want to get about 350 HP if I can, and of course, Im on a budget,,, short one...Im mostly into the 50s stuff so this is kind of out of my comfort zone... Im thinking some 9.5 comp. pistons, maybe KB, Im open to manifold and carb , need new cam advice for sure, Ill use the stock crank and rods, heads Im open to as long as it isnt spendy, ill use elec ign of course, probably some type of headers. roller chain and gears, hope I can get some good advice out there from you guys... maybe Im asking for too much.. but sure would appreciate some advice.. please email me privatly.. and again,, thanks in advance
christineman
mel@moparmel.com
Old May 29, 2010 | 05:07 PM
  #30
dodgenut7's Avatar
i run a holley 750 dual feed on my 340 in my dart and have no problems with it cruising around well except she likes to drink the fuel but thats no big deal
Monaco500-440
Aug 27, 2012 12:34 AM
crwchf16
Jun 3, 2012 03:08 AM
1966DartConvertible
Apr 3, 2012 08:06 PM
dartcuda
Mar 22, 2009 08:22 AM
Red Devil
Mar 20, 2009 11:17 PM
